order of products in a category
13 years 9 months ago #87731 by thomas.boepple
I would like to change the order of items listed in a category.
The URL is: www.juzodesign.com/index.php/categories/...2-designer-wearables
At present it is oldest first and then as I add items they go to the end of the page.
So I guess instead of ascending I have to chose descending - only where exactly do I do that?
Thomas
13 years 9 months ago - 13 years 9 months ago #87766 by Mohamed Thelji
Hi thomas,
If you want to change the ordering of your category listing, you'll just have to use the Ordering field option through "Hikashop->Display->Content menus->'Your category listing'".
Hope this will help you
Last edit: 13 years 9 months ago by Mohamed Thelji.
13 years 9 months ago #87900 by thomas.boepple
Thank you Mohamed,
logically I have no problem with the path you are pointing out - and I know the view.
My problem is this: I come to this page: www.juzodesign.com/index.php/categories/...2-designer-wearables
by comming from www.juzodesign.com/index.php/categories
So Hika shop displays the category 12 - designer - wearables, that I have created as a category. How do I get to the menu or module that gives me the option to change the ordering?
So in a nutshell- what is the path to a category - how do I alter the order of products within that category?
13 years 9 months ago #87908 by thomas.boepple
Issue solved
It has nothing to do with blindness. :)
There is an issue with the backend template - rt mission control does not display the tool bar.
Thanks for the help - as always
