- Thank you received: 4
Urgent - shipping method per product does not work
13 years 9 months ago - 13 years 9 months ago #90804
by gidgie
Urgent - shipping method per product does not work was created by gidgie
Hi Guys,
I have a site that is going live today ( not an option to delay it).
But the shipping per product does not want to work for some reason.
I need it to use flat price per product. We have set $8 per product, so if i add 2 products, shipping should be $16.
my configuration is in the screenshot attached. What am I doing wrong???
Also, is there a way to make sure that when you edit number of items in the cart the shipping methods don't reset to the default one.???
Thanks heaps!
Thanks heaps!
Last edit: 13 years 9 months ago by gidgie. Reason: MOre details became available
- Thank you received: 1778
13 years 9 months ago - 13 years 9 months ago #90856
by Mohamed Thelji
Replied by Mohamed Thelji on topic Urgent - shipping method per product does not work
If you want to use the "Use price per product" option, [strike]you'll have to :[/strike] (you can also use it by filling the "price per product option")
- Go to your products pages
- Set a price for each products and a minimum quantity products through the "Shipping prices" tab of each product's page
Hope this will help you.
Last edit: 13 years 9 months ago by Mohamed Thelji.
13 years 9 months ago #90859
by gidgie
Replied by gidgie on topic Urgent - shipping method per product does not work
HI Mohamed,
I don't have shipping prices tab on the products page. I might be using an older hikashop version or something like that.
The trouble is that my client is very uncomfortable with computers and they can hardly put in a product description, let alone 4 shipping prices for each product.
Isn't there a way to make the manual shipping method work??? Essentially we have 3 free shipping methods and one paid. So we need the paid one to work at a higher than product level... HOpe i am not asking for something too complex
13 years 9 months ago #90864
by Mohamed Thelji
Can you follow each step of the shipping
FAQ
and tell me if it solves your problem ?
13 years 9 months ago #90879
by gidgie
HI Mohamed,
I went item by item through entire list, and everything is ok.
The shipping appears ok, but it just does not multiply the shipping cost by the number of products in the cart ( they are just cases of wine, so they all are the same)
What else could be wrong :dry: ???
13 years 9 months ago #90889
by Mohamed Thelji
Ok, so can you give me a temporary access to you back-end through PM, for testing purpose ?
13 years 9 months ago #91205
by gidgie
HI Mohamed,
Just wondering if you had a chance to have a look at the issue for me. I know you guys are away till Saturday.
I will keep trying to resolve the issues, as my site is likely to get a wave of of visitors on Friday.
Fingers crossed
Fingers crossed
13 years 9 months ago #91338
Replied by nicolas on topic Urgent - shipping method per product does not work
We got the access but we're actually not able to access your backend. The URL you provided only lead to a blank page.
I don't know why you would have that without really looking into it.
However, there is a simple way to do the same without using the price per product option.
Just set the same weight for all your products, for example 1kg.
Then, create one manual shipping method per weight range like that:
from 0.5 to 1.5 kg=>8 AUD
from 1.5 to 2.5kg => 16 AUD
...etc...
That should definitely work.
...etc...
13 years 9 months ago #91379
by gidgie
Thank you for looking into this for me. Late last night as a last resourse i have installed the latest version of Hikashop and that has fixed the issue.
Thanks again!
Thanks again!
