Error when changing product code
13 years 9 months ago #91226 by sander.v.bergen
Hi there,
When I try to change the product code of a poduct (or product variant) I get the following error:
"A product with the same code already exists
Error Saving"
Even when I change the code to somthing random like "jhg234tguy2ej" (this deffinitely does not exist since I only have 5 products added so far) I get this error.
Running Joomla debug mode doesn't help me at all.
Does anyone know what the problem might be? Thanks!
13 years 9 months ago #91295 by Eliot
Hi there,
Are you using the last Hikashop version?
Could you Pm us you backend acess so we can test it?
13 years 9 months ago #91296 by Xavier
Could you give us a backend acces to see the problem ?
13 years 9 months ago #91315 by Eliot
Hi there,
It's just a bug we fixed in the last version.
Try to upload it and reinstall, it should save your problem.
The following user(s) said Thank You: sander.v.bergen
13 years 8 months ago #91889 by sander.v.bergen
Thanks!
That fixed it :).
13 years 8 months ago #91911 by sander.v.bergen
I have some additional questions. I don't know if I should post it here, or if it's better to start a new topic.
So correct me if I'm wrong ;).
1: When I go to 'categories' on my website, the 3rd sub-item in the menu is also displayed as current ( sandervanbergen.nl/tests/aquashop/ ).
I think that I might did something wrong with creating the menu item, but re-creating it won't seem to help.
2: On the product page I have a dropdown-list with characteristics. I want to remove the label in front of the list but I can't find it in the Display > Views.
The 'show_block_characteristics' view shows echo $this->characteristic->displayFE($this->element, $this->params);, but that is as far as I get.
Thank you again!
13 years 8 months ago #91978 by Xavier
1: I think that it don't come from HikaShop, but from your template. If you create another menu with not hikashop items in it, does it work fine ?
2: You can maybe use the css property "display:none;" to hide that. Try to find the class displaying the label and apply this property.
Here is a tutorial about layout customization:
www.hikashop.com/fr/support/documentatio...ize-the-display.html
13 years 8 months ago - 13 years 8 months ago #91983 by sander.v.bergen
Hi Xavier,
Thank you for your answer.
1- It only occurs with that specific menu-item. The other 3 items under 'Categorieën' don't have the class .current. It's only 'Vijverplanten'.
The menu below it, 'Account' also has two sub-items. With this menu everything goes just fine.
2- You are right. It can be hidden using '.hikashop_product_characteristics_table td:first-child{display:none;}'.
If someone knows where I can delete it in the code please let me know since I prefer that option.
Thanks again for helping out! Great support :)!
Last edit: 13 years 8 months ago by sander.v.bergen.
13 years 8 months ago #92084 by nicolas
1. I don't know but the problem is not a hikashop problem. It's joomla which displays the menu links all by itself. Maybe it comes from the fact that Categorieën is your main menu ? Maybe you could try changing your main menu and see if that helps ?
2. Why not simply turn off the option "Display the characteristics name" in the configuration ?
13 years 8 months ago - 13 years 8 months ago #92120 by sander.v.bergen
Hey,
1- Hmm... I tried making another menu item the 'home' page. That didn't solve it.
I also tried deleting both menu-items and hikashop modules. I created new menu items for 'categorieën' and 'vijverplanten', and the problem is still there.. So weird :S
But if I change 'categorieën' to something else than 'Hikashop category listing' (for example: single article) the problem is gone. So it looks like it might have something to do with the Hikashop category listing (or my configuration with that).
2- Hehe, thanks :)! Didn't know that option was there... Perfect!
[strike]EDIT: When I unpublish the category 'vijverplanten' in Hikashop the category 'aquariumplanten' gets .current. If I unpublish that one the category 'eSHa' gets .current.
It's always the last category that gets the .current class (last # category in Hikashop product cateogy list).[/strike]
EDIT: Changed the menu-items from category to product listing. Unpublishing the categories has no effect now. However, when I unpublish the menu item 'vijverplanten' the next menu item (next in order by cat. ID) becomes .current.
This only occurs when I set the parent menu item (categorieën) to category listing.
Last edit: 13 years 8 months ago by sander.v.bergen. Reason: Update
13 years 8 months ago #92406 by nicolas
Do you use the standard joomla menu module for that menu ? Could you try to use another one ?
Why not simply use a category listing content module of HikaShop instead ? That would avoid that problem for sure.
13 years 8 months ago #93067 by sander.v.bergen
- I'm using the standard module. Tried using a new (standard joomla) menu module. But that didn't fix the problem.
- I tried this at first, but the breadcrumbs didn't work as they should. Using menu items for every category fixed this.
13 years 8 months ago #93163 by nicolas
Ok,
Can you try to remove the line:
$menus->setActive($submenu->itemid);
in the file components/com_hikashop/views/category/view.html.php
That should help.
13 years 8 months ago #93206 by sander.v.bergen
That did it! :D
Thanks!!!
Is there a way to override that file? Putting it in 'mytemplate/html/com_hikashop/category' doesn't seem to work.
13 years 8 months ago #93445 by nicolas
You can't override it.
There is no need to. That modification will be included in next version of HikaShop.
13 years 8 months ago #93460 by sander.v.bergen
Ok, Thanks :D!
