Problems after updating to 2.1.0
13 years 9 months ago #91312
by tsmith
Problems after updating to 2.1.0 was created by tsmith
After updating to 2.1.0, I have encountered a few problems:
I need to get these issue solved as soon as possible.
- Image sizes are completely different for thumbnails and related products.
- My thumbnail images are old images that I have already replaced, before the update.
- It is showing a 'Display #' box on the category page. (I want to display ALL the products within its category page)
13 years 9 months ago #91389
by Xavier
Replied by Xavier on topic Problems after updating to 2.1.0
For the thumbnails issue, try to change the size of the thumbnails in the settings (Config > Main > Images) to another value, save, reload the product pages to generate thumbnails to the new size, and then re-set your old size parameters.
Or you can too delete the thumbnail folders, by this way HikaShop will generate the thumbs again.
Don't forget to make a copy before, just to be sure to not lose anything.
The following user(s) said Thank You: tsmith
13 years 9 months ago #91443
by tsmith
Replied by tsmith on topic Problems after updating to 2.1.0
Xavier,
When I changed the size of my thumbnails in the settings, it changed every product picture within each product to that size. I just went ahead and updated all the thumbnails individually.
As for the 'Display#' box at the bottom of the page, I did mess around in the frontend custom css file, but it ended up not working out. So I changed the display of my content menus to a Table layout, now all my products show up.
Everything seems to work nicely now. Thanks for your quick response, Xavier!
