cart not registering customer shopping
13 years 8 months ago #91734 by michelsacramento
I have duplicate items on display, on with price and the other without. Failing to remove the unwanted set if item display!
When one selects an item, the link to Add to cart", the pop up message says constantly: "your cart is empty".
Anybody has a clue as to why, please?
pastoralefrancophoneuk.org/fr/produits.html
13 years 8 months ago #91867 by Xavier
Could you give us a screenshot of your cart configuration, and one of a product page edition ?
13 years 8 months ago #91884 by michelsacramento
Sure!
Please see Word file attachment
13 years 8 months ago #92006 by michelsacramento
Xavier, Est-ce que tu pourrais aider a fixer mon probleme de cart qui n'enregistre pas les selections du client et qui m'envoie le popup message: "votre panier est vide"?
Par ailleurs, je voudrais avoir le module login, le module cart, et le module categories des produits sur une meme page web
13 years 8 months ago #92265 by nicolas
Thank you for not posting your questions on both the forum and our contact form. It means more work for us and thus less time to help everyone and improve HikaShop.
I already gave the solutions to all of that via email
The add to cart buttons that you added in the description of your
products are not valid. You actually don't need to do that. Simply
turn off the catalog mode of the configuration and you will see the
add to cart buttons of HikaShop automatically.
On your screenshot, you have a category called 2013: my Year of
Expension, Bishop Stephen Irie and a product with the same name.
That's two different things.
I don't know why you created a category with the same name as a
product if you don't need to category. Simply delete the category and
voilà.
Regarding the menu title which is squashed, that's because of your template CSS.
You have the CSS:
#rt-main ul.menu {
margin: -11px;
padding: 0;
in the file pastoralefrancophoneuk.org/templates/ca_...j17/css/template.css
Remove the margin line there and it will display normally.
13 years 8 months ago #93151 by michelsacramento
I have tried deleting those categories dozens of times, in VAIN. I am stuck here...
As for the module display squashed, I have modified the related CSS entry as recommended.
That's fine now, thanks.
13 years 8 months ago #93152 by michelsacramento
NB: the issue with categories is that it is happening for the Livres and CDs categories, but not on the DVDs category, which is just odd!
13 years 8 months ago #93164 by michelsacramento
Would you mind send me a screenshot of the place where you turn off the catalog mode in the general configuration, please?
13 years 8 months ago #93167 by michelsacramento
Sorry! I think I have found the catalog radio button to turn off the active mode.
13 years 8 months ago #93196 by michelsacramento
I have finally managed to delete the redundant categories. But I still get a doubled display of each item. Any idea where might come from?
13 years 8 months ago #93475 by nicolas
I don't see the items in double on your pages. Can you give a link to a page where that happens ?
13 years 8 months ago #93486 by michelsacramento
I have been working on this every day, without much success! But there are some changes.
On the this page: pastoralefrancophoneuk.org/fr/e-shopping.html
at the bottom, it is colored and inconsistant in contents. A mixture of categories items
Besides, I cannot get items per category to display in three columns instead of one, so that visitors need not to scroll down that long.
13 years 8 months ago #93489 by michelsacramento
I have difficulties removing the second description of a selected item:
13 years 8 months ago #93554 by Xavier
To display in 3 columns, you have to change the parameters of the associated module of the menu "hikashop-menu-for-categories-listing". You can access it via, Display > Content menu, then "Associated module.."
For the description, you have to edit the view "product / show_tabular" in Display > Views and remove the first instance of the description.
13 years 8 months ago #93609 by michelsacramento
Thanks for coming back to me. But I dont get it. My Hikashop is in the French version, so I need to juggle with what you are trying to suggest and instructions that make no sense to me immediately such as: "you have to edit the view "product / show_tabular" in Display > Views and remove the first instance of the description." Please provide screenshots
13 years 8 months ago #93655 by michelsacramento
I have tried to change the config of the list of associated products as directed. It seems not to work as expected. Here is a screenshot:
13 years 8 months ago #93668 by michelsacramento
I have some issues such as display of dots left of the item boxes:
, I cannot work out why this placeholder entry "{hikashop_social}" appears here
and how can I reduce the width of these item boxes to a eourth of its actual width, etc.
I have tried to remove the second display of item description in vain:
I need serious straightforward help here, please.
NB: my hikashop is in a french version
Many thanks
13 years 8 months ago #94038 by nicolas
Regarding the fact that your products are stuck on one column instead of several like you configured them, that's because your template doesn't handle the "thumbnails" component of bootstrap ( twitter.github.com/bootstrap/components.html#thumbnails ) and that you selected "thumbnails" as "item box border" in the hikashop options of your products listing.
Change that option to use a normal border and that should work.
You will find that option in the options of the module with the id 167 that you cane edit via the menu Display>Content modules.
To remove the first description on the product page it's quite simple. Add the CSS below in the frontend CSS file of HikaShop via the interface in the configuration page of HikaShop:
.hikashop_product_description_main_mini{ display:none; }
NB: If you want answers in French, then post your questions in French on our French forum.
13 years 8 months ago #94354 by michelsacramento
The double description is now sorted. Thanks!
However, the changes you suggest are not produising the results expected. See the screenshot.
I have made the same amendments on all for listings, no improvement.
Note:
1 - there is no borders anymore, but the decoration of the un-ordered lists (I guess the dots left to the items represent that decoration) are still visible.
2 - I do find the occasional {hikashop_social
13 years 8 months ago #94585 by nicolas
I checked a bit further the code on your page and I see that you have activated the option "boostrap design" in the configuration of HikaShop. However, your template does not use bootstrap. Please turn off that option and it will work fine.
Regarding the social network plugin, it seems to come from some cache on your website. Please make sure that all the caching is turned off.
Time to create page: 0.143 seconds
