Wishlist access from product listing doesn´t work
13 years 7 months ago #94656
by Xavier
Replied by Xavier on topic Wishlist access from product listing doesn´t work
You can add another class on it, like cust_add_wishlist and in this property remove the border and the background.
It's a css issue, not really related on HikaShop
www.hikashop.com/fr/support/documentation/106-faq.html
www.hikashop.com/fr/support/documentatio...ize-the-display.html
The following user(s) said Thank You: Woxxx
13 years 7 months ago #95088
by Woxxx
Replied by Woxxx on topic Wishlist access from product listing doesn´t work
Hi Xavier,
After checking the website I have seen that the content (Beliebte) from a position have moved in product details. To try out I set quantity.php to default and the content was back on the right side again. So the problem must come from there. I was trying out add some } but it hasn`t solved the problem. Even with the code you published 5 days ago in this topic I get this problem.
13 years 7 months ago #95239
by Xavier
Thanks to try this quantity content:
<?php
$user = hikashop_loadUser();
if(!isset($this->cart)) $this->cart = hikashop_get('helper.cart');
if(!empty($this->row->has_options)){
echo $this->cart->displayButton(JText::_('CHOOSE_OPTIONS'),'choose_options',$this->params,hikashop_completeLink('product&task=show&product_id='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway),'window.location = \''.str_replace("'","\'",hikashop_completeLink('product&task=show&product_id='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway)).'\';return false;','');
}else{
$config =& hikashop_config();
$url = '';
$module_id = $this->params->get('from_module',0);
if(empty($this->ajax)){
$this->ajax = 'return hikashopModifyQuantity(\''.$this->row->product_id.'\',field,1,0,\'cart\','.$module_id.')';
if(@$this->row->product_sale_start || empty($this->element->main)){
$start_date = @$this->row->product_sale_start;
}else{
$start_date = $this->element->main->product_sale_start;
if(@$this->row->product_sale_end || empty($this->element->main)){
$end_date = @$this->row->product_sale_end;
}else{
$end_date = $this->element->main->product_sale_end;
if($end_date && $end_date<time()){
<span class="hikashop_product_sale_end">
<?php echo JText::_('ITEM_NOT_SOLD_ANYMORE'); ?>
</span>
<?php
}elseif($start_date && $start_date>time()){
<span class="hikashop_product_sale_start">
<?php
echo JText::sprintf('ITEM_SOLD_ON_DATE',hikashop_getDate($start_date,$this->params->get('date_format','%d %B %Y')));
//TODO echo $this->cart->displayButton(JText::_('Pre-order and add to cart'),'add',$this->params,$url,$ajax);
</span>
<?php
}elseif(!$this->params->get('catalogue') && ($this->config->get('display_add_to_cart_for_free_products') || !empty($this->row->prices))){
if(@$this->row->product_min_per_order || empty($this->element->main)){
$min = @$this->row->product_min_per_order;
}else{
$min = @$this->element->main->product_min_per_order;
if(@$this->row->product_max_per_order || empty($this->element->main)){
$max = @$this->row->product_max_per_order;
}else{
$max = @$this->element->main->product_max_per_order;
if($min<=0){
$min=1;
$formName = ',0';
if (!$this->config->get('ajax_add_to_cart', 0) || ($this->config->get('show_quantity_field')>=2 && !@$this->element->product_id)) {
if(empty($this->formName)) {
if(@$this->row->product_id)
$formName = ',\'hikashop_product_form_'.$this->row->product_id.'_'.$this->params->get('main_div_name').'\'';
else
$formName = ',\'hikashop_product_form_'.$this->params->get('main_div_name').'\'';
} else {
$formName = $this->formName;
$wishlistAjax = 'if(hikashopCheckChangeForm(\'item\''.$formName.')){ return hikashopModifyQuantity(\'' . (int)@$this->row->product_id . '\',field,1' . $formName . ',\'wishlist\','.$module_id.'); } else { return false; }';
if($this->row->product_quantity == -1 && !empty($this->element->main) && $this->element->main->product_quantity != -1){
$this->row->product_quantity = $this->element->main->product_quantity;
$btnType = 'add';
if($this->row->product_quantity==-1){
<div class="hikashop_product_stock">
<?php
if($this->params->get('add_to_cart',1)){
echo $this->cart->displayButton(JText::_('ADD_TO_CART'),'add',$this->params,$url,$this->ajax,'',$max,$min);
$btnType = 'wish';
if($this->params->get('add_to_wishlist') && $config->get('enable_wishlist', 1) && (($config->get('hide_wishlist_guest', 1) && hikashop_loadUser() != null) || !$config->get('hide_wishlist_guest', 1))){
echo '<div id="hikashop_add_wishlist">';
if($user == null){
?><input class='hikashop_cart_button' type='button' value='<?php echo JText::_('ADD_TO_WISHLIST'); ?> onclick='window.location="http://www.mydinx.com/login.html/"'/> <?php
}else{
echo $this->cart->displayButton(JText::_('ADD_TO_WISHLIST'),$btnType,$this->params,$url,$wishlistAjax,'',$max,$min,'',false); //Old code
echo '</div>';
}elseif($this->row->product_quantity>0){
<?php
echo '<span class="hikashop_product_stock_count">'.JText::sprintf('X_ITEMS_IN_STOCK',$this->row->product_quantity).'</span><br/>';
if($config->get('button_style','normal')=='css'){
echo '<br />';
if($max<=0 || $max>$this->row->product_quantity) $max = $this->row->product_quantity;
$btnType = 'wish';
if($user == null){
}else{
echo '</div>';
}else{
<div class="hikashop_product_no_stock">
<?php
echo JText::_('NO_STOCK').'<br/>';
$waitlist = $this->config->get('product_waitlist',0);
if(hikashop_level(1) && ($waitlist==2 || ($waitlist==1 && (!empty($this->element->main->product_waitlist) || !empty($this->element->product_waitlist))))){ ?>
</div><div id="hikashop_product_waitlist_main" class="hikashop_product_waitlist_main">
<?php
$empty='';
jimport('joomla.html.parameter');
$params = new HikaParameter($empty);
echo $this->cart->displayButton(JText::_('ADD_ME_WAITLIST'),'add_waitlist',$params,hikashop_completeLink('product&task=waitlist&cid='.$this->row->product_id),'window.location=\''.str_replace("'","\'",hikashop_completeLink('product&task=waitlist&cid='.$this->row->product_id)).'\';return false;');
if($this->params->get('add_to_wishlist') && $config->get('enable_wishlist', 1)){
if($user == null){
}else{
echo '</div>';
</div>
<?php
13 years 7 months ago #95637
by Woxxx
Hi Xavier,
with the last code the add to wishlist button disapeared. On the bottom you can see how I left the code. This one works fine for me.
I stiil have problems when I delete a product from the wishlist. If I do so I get redirected to
www.mydinx.com/product/updatecart/delete..._product_id-308.html
And get
Notice: Undefined variable: conf in /var/www/vhosts/mydinx.com/httpdocs/components/com_hikashop/controllers/product.php on line 389 Fatal error: Call to a member function get() on a non-object in /var/www/vhosts/mydinx.com/httpdocs/components/com_hikashop/controllers/product.php on line 389
<?php
* @version 2.1.0
* @author hikashop.com
?><?php
}else{
$url = '';
}else{
}else{
</span>
<?php
<?php
</span>
<?php
}else{
}else{
if($min<=0){
$min=1;
$formName = ',0';
else
} else {
$btnType = 'add';
<?php
$btnType = 'wish';
if($user == null){ // www.mydinx.com/login.html
echo "<input class='button_add_wishlist' type='button' value='".JText::_('ADD_TO_WISHLIST')."' onclick='window.location = \" www.mydinx.com/login.html/\"'/ >";
else{
echo '</div>';
<?php
echo '<br />';
$btnType = 'wish';
else{
echo '</div>';
}else{
<?php
<?php
$empty='';
else{
echo $this->cart->displayButton(JText::_('ADD_TO_WISHLIST'),'add',$this->params,$url,$wishlistAjax,'',@$this->row->product_max_per_order,1,'',false);
echo '</div>';
</div>
<?php
And get
<?php
* @version 2.1.0
?><?php
}else{
$url = '';
}else{
}else{
</span>
<?php
<?php
</span>
<?php
}else{
}else{
if($min<=0){
$min=1;
$formName = ',0';
else
} else {
$btnType = 'add';
<?php
$btnType = 'wish';
else{
echo '</div>';
<?php
echo '<br />';
$btnType = 'wish';
else{
echo '</div>';
}else{
<?php
<?php
$empty='';
else{
echo '</div>';
</div>
<?php
13 years 7 months ago #95648
by Xavier
Do you have HikaShop 2.1.1 ?
And have you edited the controller product ?
13 years 7 months ago #95676
by Woxxx
After update the problem was fixed.
Thank you Xavier
Thank you Xavier
