Mulitple image for products
13 years 8 months ago #92723 by isabelleandco
Is it possible, once an image for a product is clicked, to scroll through the images by simply clicking on an arrow or something?
This would be similar to how Amazon does this.
Is this possible, or is this a feature that might be being working on in the future?
13 years 8 months ago #92761 by Mohamed Thelji
Sure that's possible via this integration .
Hope this will help you.
13 years 8 months ago #93532 by isabelleandco
Ok, I followed the instructions but it didn't seem to work.
13 years 8 months ago #93568 by Mohamed Thelji
Did you follow all steps (downloaded the plugin/enabled it/applied the override) ?
13 years 8 months ago #93796 by isabelleandco
yep
13 years 8 months ago #93904 by Xavier
Replied by Xavier on topic Mulitple image for products
The way the popup is displayed has changed ? Or is it the same as before ?
Thanks to be more precise on what is not working. We are not soothsayers :)
13 years 8 months ago #94236 by isabelleandco
The way that it shows now is that the other images show below the main image.
Like so:
s446956729.onlinehome.us/index.php/compo...106-elizabeth-top-64
What we would like is once any of the images are clicked, then it pops up in a shodowbox and viewers can click through. I followed the instructions and this is not working yet.
13 years 8 months ago #94322 by Xavier
Are you sure that you have put the files in the good template folder ?
Which version of Joomla are you using ?
13 years 8 months ago #94524 by isabelleandco
HA! I figured it out. I neglected to put it in the "HTML" folder under the template folder. PFT. It's all good now. THANKS!
13 years 1 week ago #133232 by commander64
I'm testing Hika shop starter and the integration of Shadowbox Media Player with the override file in HTML folder of my Template.
Everything works fine, exept: The first picture is shown 2 times . (I think, there was a discussion about that in the past but I didn't find a solution for that :( ). I deleted also the part:
$this->setLayout('show_block_img');
echo $this->loadTemplate();
in the "show" file but without success. Is ther any other solution to prevent this issue ?
Tom
13 years 1 week ago #133345 by Mohamed Thelji
Hi Tom,
Can you show me some screenshots of the issue that you are having and of how you configured your product "images" tab ?
Thank you.
13 years 1 week ago - 13 years 1 week ago #133352 by commander64
No problem
Fist picture: you see 3 thumbs of the produkt
Second picture : if you "start" shadowbox, the first image is show 2 times ( 1-4 )
Normally there should be (1-3)
Last edit: 13 years 1 week ago by commander64.
13 years 6 days ago #133400 by nicolas
Replied by nicolas on topic Mulitple image for products
There is no solution for that. The way the shadow box player system is done we can't do differently.
We'll have to create our own image gallery system in the future in order to do that properly.
