I have a problem with the links of the categories.
13 years 8 months ago #93973 by gaforex
the menu link appears this way:
latiendadelaesteticista.com/index.php/cosmetica/selvert
however if you access the category des Hikashop looks like this:
latiendadelaesteticista.com/index.php/cosmetica /category/22-selvert
ID number appears in the category, as do the links are the same, whether the id as if?
because /category is as des remove Hikashop configuration.
13 years 8 months ago #94030 by nicolas
You website is offline so I can't look at your menu structure nor at the version of HikaShop you're using. Make sure that you're using the latest one and if you have a main menu with sub menus, the system should use the correct links.
