many basic questions
13 years 8 months ago - 13 years 8 months ago #95391 by lionel75
1) In this page , the first capture screen show 2 items with "Hikashop product tag XXX plugin". By installing the last hikashop version ( first free) , only "Hikashop product tag insertion plugin" appear not "Hikashop product tag translation plugin". could someone explain why ?
2) What is the relation/difference beetween Article ( Joomla) and Product ( Hikashop) ?
3) Does hikashop is compatible with joomfish ?
4) Does joomfish is compatible with Joomla 25 ?
5) which ( image,price ?,cart ?, tva ?, summary, description,brand, availaibility) and where ( table name) are store the informations about one product in RBDMS database ?
6) is there an easy way to import/export table content of product in database to make them available to hikashop / joomla ?
7) can we add custom input form to the default product definition ( when create a specific kind of product) and make access to any of them using joomla search form ?
8) Is there available link to third company that use hikashop for their bussines instead of the demo web page ? i search something like this page but for hikashop .
thank's to any help
Last edit: 13 years 8 months ago by lionel75.
13 years 8 months ago #95435 by nicolas
Replied by nicolas on topic many basic questions
1. It's called HikaShop product insert. The name has not yet been changed (it will in next version of HikaShop).
2. A Joomla article is displayed by Joomla and is just text. A HikaShop product has a text in its description, but also prices, weight and dimensions, quantity, add to cart button, etc.
3. yes
4. yes
5. The product data is stored in the hikashop_product table. The order summary data is stored in the hikashop_order and the hikashop_order_product tables. The product price data is stored in the hikashop_price table. The cart data is stored in the hikashop_cart and hikashop_cart_product tables.
6. You can use our import system: www.hikashop.com/en/support/documentatio...hikashop-import.html
7. Yes. You can do that with HikaShop Essential and HikaShop Business by creating a custom product field via the menu Display->Custom fields. Then, in the HikaShop product search plugin, you can select these custom fields for the search.
8. You will find hundred of such websites in our showcase area here:
www.hikashop.com/en/forum/8-showcase.html
