Problem with Hikashop plugin for xmap
13 years 7 months ago #97033 by jeff_heilman@comcast.net
I've been having problems with the Hikashop plugin for x-map. Xmap will generate the sitemap fine when the plugin is disabled but without the Hikashop categories and products. With the plugin enabled it will not create a proper xml sitemap no matter what depth I set on the categories or what combination of the xmap plugins I enable or disable.
I've found a few other threads where people have the same issue but I couldn't find a definitive answer. I'm using xmap 2.3.2 with Joomla 2.5 and Hikashop Business.
Any suggestions on what to do would be greatly appreciated! Thanks.
Jeff
13 years 7 months ago #97047 by nicolas
The latest version of the hikashop plugin for xmap is working fine as far as we know.
Can you make sure you're using the latest version ?
Also, please provide the exact error you have if that doesn't help.
