Hikashop content module not working as expected
13 years 7 months ago #97135 by Sjaak
Yesterday I purchased Hikashop Business and Multivendor. I managed to import my VMshop OK.
Now I try to get the Hikashop content module to work and can't get it done. Can somebody help?
I prefer to show a list of my main categories (22). I'd like to show the subcategories when clicking the main category. Then I want to show the products after clicking the subcategory.
What happens is that main categories are showing in the menu. Clicking them opens a new page. ----> but its the 'edit useraccount form' that opens. No matter what category is clicked it always shows the 'edit useraccount' page. I tried many options but it doesn't change. Am I doing something wrong.
Sjaak
13 years 7 months ago #97142 by nicolas
This sounds like SEF issue. If you turn off SEF, does it work ? If so, make sure that you select a category listing menu item in the "menu" hikashop option of your module.
13 years 7 months ago - 13 years 7 months ago #97150 by Sjaak
Thank you Nicolas,
Turning off SEF helped.....in a way. Now it seems that the clicked category shows.
The breadcrumb trail shows a path to the category but the page is still empty.
Does this mean I cannot use the standard joomla SEF feature anymore?
I do not fully understand your explanation. Can you explain more? I attached a screenshot of my current settings.
When the category shows the module disappears. I want to show the module on ALL pages. As it is now my clients cannot browse to another category while being in another one. They need to go back all the way to choose another one. What can I do to solve that?
Sjaak Boer
Last edit: 13 years 7 months ago by Sjaak. Reason: Forgot to attach screenshot.
13 years 7 months ago #97320 by Xavier
What Nicolas said is, you have to change the value for the option "Menu". Actually it's "Menu item for category listing module 145". Thanks to try with "Category listing" or another one.
13 years 7 months ago #97382 by Sjaak
Hi Xavier,
The listing you propose is not available in the dropdownlist that opens so I set it to 'none'. Now the products in the category are shown on the page. But on top of the page this remark also shows: 'Notice: Trying to get property of non-object in /var/www/vhosts/artlantismedia.com/httpdocs/administrator/components/com_hikashop/helpers/helper.php on line 409'
What does it mean?
Sjaak
13 years 7 months ago #97410 by Xavier
Could you give us the code present at the corresponding line ? (and two lines before and after)
13 years 7 months ago #97415 by Sjaak
HI Xavier,
I am not good with coding. I don't know how to look at line *** or line ***. Never understood how it works.
I send you the file via PM
Sjaak
13 years 7 months ago #97485 by Xavier
I can't reach the file with a backend access. I need a ftp access.
To have the lines you have to go via ftp at the address "administrator/components/com_hikashop/helpers/helper.php" open it in notepad++ and on the left side you should see the numbers.
13 years 7 months ago #97500 by Sjaak
Hello Xavier,
Thanks for your advice. I downloaded and installed Notepad++. Very helpfull.
I copied the lines 391-420 and pasted them below:
if(!isset($user)){
$user_id = (int)$app->getUserState( HIKASHOP_COMPONENT.'.user_id' );
$class = hikashop_get('class.user');
if(empty($user_id)){
$userCMS = JFactory::getUser();
if(!$userCMS->guest){
$user_id = $class->getID($userCMS->get('id'));
}else{
return $user;
$user = $class->get($user_id);
if($full){
return $user;
}else{
return $user->user_id;
function hikashop_getZone($type = 'shipping'){
$shipping_address = $app->getUserState( HIKASHOP_COMPONENT.'.'.$type.'_address',0);
$zone_id =0;
if(!empty($shipping_address)){
$useMainZone=false;
$id = $app->getUserState( HIKASHOP_COMPONENT.'.shipping_id','');
if($id){
I don't know coding but am I reading correct that the userID is not recognized?
How can I solve it?
Sjaak
13 years 7 months ago #97649 by Xavier
The error seems to come from the helper file of HikaShop, one of the main files.
We never had reports on that, it's about the loaduser function which is working fine.
Are you using a third component to manage the user registration on the Joomla website ?
13 years 7 months ago #97655 by Sjaak
Hi Xavier,
Before I installed Hikashop I had Joobi software installed. To cut a long story short. I struggled 1,5 year with it and their support. They couldn't meet their promises so I decided to go another way.
The Joobi software does have another way to manage user registration. Before installing Hikashop I uninstalled every Joobicomponent. At least I thought I did. Now I'm a bit puzzled whether there are some leftovers of the @#$%^&*software.
Do you have a clue where to look?
Sjaak
13 years 7 months ago #97712 by Sjaak
Hi Xavier
Today I removed every file/directory I could find related to joobi software. A lot of 'trash' was left behind after uninstalling the software.
However I still have the same error.
Any clues where to look next?
Sjaak
13 years 7 months ago #97850 by Sjaak
So this loaduser function tries to find a user? Correct me if I'm wrong. I'm not a coder. Just an innocent user of the software.
I am building the shop and the shop is not online. I can only visit the shop as superuser/administrator.
Am I correct that my user ID cannot be found by this loaduser function?
Is something going wrong between the Joomla user registration and the Hikashop user registration?
Sjaak
13 years 7 months ago #97955 by nicolas
Go in the joomla configuration page and turn off the "error reporting" option.
You don't want it on on a production server anyway.
And yes that means that the current user is not found in HikaShop.
That comes from a synchronization issue with the user which could happen if the hikashop user synchronization plugin is unpublished and that a user is created. So please make sure that this plugin is published.
13 years 7 months ago #97964 by Sjaak
Thank you Nicolas,
I already had turned off error reporting. It appeared I still had 'debug system' turned on. After turning that off the message disappeared. I don't think it really solves the 'problem' It is just not visible anymore.
I previously already had turned on the hikashop user synchronisation plugin and the error still showed.
Well I don't think it is a big matter. I prefer users to register via Hikashop so I don't think it will bother us anymore.
That means turning on the 'Redirect Joomla registration to HikaShop Plugin', am I right?
Sjaak
13 years 6 months ago #98228 by nicolas
No, it's the Hikashop User Synchronization plugin which needs to be turned on so that users are both added to HikaShop and Joomla when they register.
Note that if you had a problem with an existing user, publishing the plugin won't help for that user as it works only when you create/save the user.
