Filter's mechanics
13 years 7 months ago #97527 by Shulha
Filter's mechanics was created by Shulha
Hello. My topic concerns filters' mechanics. If you apply a filter to some parameter, and then click, for example, on the other Main Menu item and then comeback to the Catalogue where the filtering was made, you will still have the filters working. I find it incredibly unusable. I mean that logically, when you click again on the catalogue, you expect that no filter will be applied, that you will the the whole catalogue.
So, I hired a web-developer, he applied some features to the website, but when I asked him to make this - You apply a filter in the "Catalogue" menu, then go to another and when you comeback, you have no filter applied. He told me that its impossible because of the info about the applied filters is stored in cookies.
Well. So I ask you as developers, is there ANY way to do something like this? This is incredibly urgent. I mean auto-resetting when you click on the Menu Item where you applied this filter. If there any, could you please descrcibe it more precisely, so as the developer could get it? And plus, the Basket items should not be lost.
Thanks a lot.
13 years 7 months ago #97752 by Xavier
Replied by Xavier on topic Filter's mechanics
You have to edit the file "administrator/components/com_hikashop/classes/filter.php" and in the function "addFilter()" replace the line:
$infoGet = $app->getUserStateFromRequest( 'com_hikashop.'.$cid .'_filter_'.$filter->filter_namekey.$completion, 'filter_'.$filter->filter_namekey.$completion, $infoGet, 'array' );
By:
$infoGet = JRequest::getString('filter_'.$filter->filter_namekey.$completion);
The filters are not stored in cookies but in session.
13 years 7 months ago #98009 by PeterChain
Replied by PeterChain on topic Filter's mechanics
Could somebody confirm this is a realistic way of making an "ALL AT ONCE FILTER RESET" ?
This is a MUST function which without it makes browsing the catalog an unacceptable experience for most clients.
13 years 7 months ago #98149 by Xavier
By this way the filters are not taken from the session but from the "POST".
So when going to another page, the filters values are lost, so reset.
You just have to try :)
The following user(s) said Thank You: PeterChain
13 years 7 months ago #98156 by PeterChain
GREAT! This brings some light to the filtering issue! I'll try as soon as possible.
13 years 7 months ago #98232 by Shulha
Replied by Shulha on topic Filter's mechanics
Xavier wrote: Hi,
What if i dont have this line in addFilter function in filter.php :
$infoGet = $app->getUserStateFromRequest( 'com_hikashop.'.$cid .'_filter_'.$filter->filter_namekey.$completion, 'filter_'.$filter->filter_namekey.$completion, $infoGet, 'array' );[
13 years 7 months ago #98280 by PeterChain
I TRIED AND IT WORKS.
Shulha, if you don't find the required string you might be editing a wrong filter.php file. Make sure you are editing the one in the 'classes' folder.
Anyway this is not still the right solution as you may get reseted filter but the Filter controls remain with the X sign to get them cancelled even they are already cancelled.
Suggestions will be welcom on how to refresh the Filters controls to initial status.
13 years 6 months ago - 13 years 6 months ago #98998 by PeterChain
Is this "Code Tweak" still valid for 2.1.2 ?
Looks like this file and the way to call its functions experienced a large amount of changes since 2.1.0
Last edit: 13 years 6 months ago by PeterChain.
13 years 6 months ago #99143 by Xavier
The way the filters are working don't changed.
The "code tweak" is still valid.
13 years 5 months ago - 13 years 5 months ago #108378 by PeterChain
NOTE TO USERS WANTING TO TAKE ADVANTAGE FROM THIS:
For HikaShop 2.1.3 you have to find this string
$infoGet = $app->getUserStateFromRequest( 'com_hikashop.'.$cid .'_filter_'.$filter->filter_namekey, 'filter_'.$filter->filter_namekey, $infoGet, 'array' );
Last edit: 13 years 5 months ago by PeterChain.
The following user(s) said Thank You: Xavier
13 years 3 months ago #113864 by alikon1
Replied by alikon1 on topic Filter's mechanics
PeterChain wrote: Anyway this is not still the right solution as you may get reseted filter but the Filter controls remain with the X sign to get them cancelled even they are already cancelled.
Yes. Filter module shows that filter is applied, but all products from category are listed. How to reset selection in module too? It confuses the site visitors.
13 years 3 months ago #113899 by Eliot
Replied by Eliot on topic Filter's mechanics
Hi there,
The last Hikashop version includes the possibility to display a reset button.
You can find this option in System>Configuration>Features>Filters
13 years 3 months ago #113903 by alikon1
Eliot wrote: Hi there,
I want clear filter after change category without pressing any buttons. Just open category and there is no any filter applied...
13 years 3 months ago #113921 by mariussport
Replied by mariussport on topic Filter's mechanics
Thanks,
we had the same question about the filter function.
regards, Marius
13 years 3 months ago #114053 by Eliot
Hi there,
Actually this is the current behavior of the filters, it's reseted for each category.
Could you please give me a link to your website so I can test it?
13 years 3 months ago #114059 by mariussport
Hi Eliot,
Thank you. After the update to 2.20 the reset button in the configuration and the filter module is activated.
Seems to work much better now, only one thing, after reset the "Search text" doesn't dissapear in combination of the menu "Article List"
You can test it on the website. [url=http://] www.lebasport.nl [/url]
best regards,
Marius
13 years 3 months ago #114061 by alikon1
It's in russian. I think you don't understend anything on this site.
When I use filter, it works and show for example 2 products from category
But when I change category and then return here again, there will be listed all products, but filter module shows like filter is still applied. But really no filter is applied.
13 years 3 months ago - 13 years 3 months ago #114062 by Eliot
@Marius: Could you send me a PM with a backend access and a FTP access as well as a link to this topic?
I reproduced the bug so I'll try to fix it.
@alikon1: Do you have the last Hikashop version? And a link to your website could also help me
Last edit: 13 years 3 months ago by Eliot.
13 years 3 months ago #114087 by Eliot
Hi Marius,
I found the source of the issue, it's because you activated the joomla's cache.
That's why the filter is working but not displaying the right informations, the page is cached.
So you ahve to disable the joomla's cache and if you really want to have a cache you must find an extension to specify the pages you want to cache (not the Hikashop ones)
13 years 3 months ago #114089 by mariussport
Hi Eliot,
Thank you for your work and that you have found the issue. Good luck,
Marius
Time to create page: 0.099 seconds
