Error exporting products to .csv
13 years 7 months ago - 13 years 7 months ago #99518 by scharfet
I have problems with exporting products.
When I export only a fiew I have o problem. But when I do not mark any products in order to export all of them (135 products) following messege is written in the .csv-file and the generation of the file takes several minutes.
<b>Warning</b>: Invalid argument supplied for foreach() in <b>/ homez.428/monpetit/www/libraries/joomla/database/database/mysql.php</b> on line <b>375</b><br />
When importing the csv file what does this option mean? What is the difference between uptade and replace? Hikashop > Products > Import:
  • Update the product quantity instead of replacing it
I whant o export the products to to raise an inventory and then I whant to import the csv file again with the current cuantity of my stock.
I tried to import and import one product for texting and I got this error:
Thank you.
Last edit: 13 years 7 months ago by scharfet.
13 years 7 months ago #99616 by nicolas
It sounds like your CSV is not correct. But without looking at your CSV I can't say much.
You should keep the option "Update the product quantity instead of replacing it" off for what you want to do.
The warning in Joomla is not relevant.
