What plugins are required for functionality?
13 years 6 months ago #99661 by brentwilliams2
I am trying to trim down the number of active plugins on my site, but I'm concerned about removing plugins that might mess up functionality. Is there a way to determine which plugins are critical versus not?
13 years 6 months ago #99666 by nicolas
It depends on the functionalities that you're using...
If you're using the geolocation, the geolocation plugin is necessary. If you're using the search plugins, then you need them, etc.
