Alert box for required fields
13 years 7 months ago #101212 by aheng5
Not sure if this has been addressed elsewhere. On some items where I need to have required custom fields complete, no alert box appears, but on others it does. It's the same content module that has all three produces in the same category.
Is there something I'm not setting right? See attached module settings.
I'm using Joomla 3.
The relevant link is Membership form
If one does not fill in any fields, only the Teacher/staff item pops up alert but the Parent and Student products doesn't result in an alert box.
This is very puzzling to me.
13 years 6 months ago #101327 by Jerome
First, your template include jQuery more that needed which create some javascript errors.
It could explain that some javascript is not running in the page so, some messages are not displaying.
After that, the alert boxes on custom fields are managed by the form itself, not the custom field elements.
The address form checks his values before the submit, the "add to cart" might not.
13 years 6 months ago #101349 by aheng5
Interesting that you mention my problem may be my custom template. So I've tested to use the default template that comes with Joomla 3 and the issue is still there; no alert box on the required fields if they are blank:
Join PTSA link
but all the alert works correctly only this page
JAG Fund
So this is quite puzzling to me.
I don't think your jquery comment is causing the problem. I've deleted and recreated the products and categories as well as placing these two order pages on different template.
Hope you can discover the solution to my dilemma.
13 years 6 months ago #101519 by nicolas
I just checked your website fcptsa.webevolutionary.com/
On both fcptsa.webevolutionary.com/component/hikashop/user/form.html and fcptsa.webevolutionary.com/component/hikashop/checkout.html regsitration forms, I can see the alert boxes for the custom address fields and for the email fields.
So I couldn't see any problem actually.
13 years 6 months ago #101521 by aheng5
I'm doing more testing and did a clean uninstall/reinstall. I'll let you know how it goes. Unfortunately I'm still have the same issues.
