- Thank you received: 16
Templating the HikaShop products when Acybed
- PeterChain
13 years 6 months ago #104081
by PeterChain
Templating the HikaShop products when Acybed was created by PeterChain
How to template of the output of HikaShop products into Acymailing newsletters?
The interface works fine, but I don't get the look I want and don't know where to start. I hope there is some tempalting feature...
13 years 6 months ago #104084
Replied by nicolas on topic Templating the HikaShop products when Acybed
Yes, this is possible by following the information on the documentation of the plugin on acymailing's website:
www.acyba.com/en/support/documentation/1...ashop.html#customize
- PeterChain
13 years 6 months ago #104086
by PeterChain
Replied by PeterChain on topic Templating the HikaShop products when Acybed
This is the answer I got from Acyba in the case somebody needs it:
You can indeed create your own file and the plugin will use this file instead of using the default layout.
