Backend Menu Screwed Up. Help Please!
13 years 6 months ago #105148 by Juilbox
Please see attached, the backend Hikashop menu is really screwed up, I cannot for the life of me figure out where to fix this.
13 years 6 months ago #105149 by Jerome
Please check your CSS files are right.
The CSS used in the backend for the menu is not loaded properly. The icon for the "dashboard" button is not displayed too.
It looks like the CSS files are no correctly loaded.
These files are in the folder "media/com_hikashop/css" : backend_default.css and menu.css
13 years 6 months ago #105160 by yideaz
Didn't work. I just completely reinstalled Hikashop. Same thing.
13 years 6 months ago #105167 by Jerome
You can have something broken in the web page. Your browser will be your best ally in order to know which file are loaded in the page.
Did you check your files ?
I didn't say you had to reinstalled HikaShop, I said you have to check the files and see if there are accessible.
If you have a custom backend file which override the default css file, it could explain some things but not all points.
Please look at the html content of a page or check the "errors" given by your browser.
