Problem safari and IE add to cart list view slider
13 years 5 months ago #106264 by dvdf77
My problem is that in the view of the product as a slide when you click add to cart to access the product page that I would like to add to cart without entering the product page.
This pproblema though, and this only on IE and not on firefox SAFARI where he works properly.
I apologize for my translation
thanks for the 'attention
13 years 5 months ago #106287 by Jerome
Do you have a link ?
I think you have a javascript error in Internet Explorer so the slider javascript is not initialize properly but, without a link I can't be sure.
The following user(s) said Thank You: dvdf77
13 years 5 months ago #106290 by dvdf77
my site is offline because it is being built around you the login information in private
this is the link:
desyou.com/collezioni-e-shop/collezione-...iceria/diamante.html
13 years 5 months ago #106341 by nicolas
The link that you provided does not work.
Can you please double check it ?
I looked a bit around on your website frontend but didn't find the carousel.
13 years 5 months ago - 13 years 5 months ago #106350 by dvdf77
this is the page: " www.desyou.com/collezioni-e-shop/collezi...iceria/diamante.html "
.... I'm sorry I was wrong to write the link
the site is temporarily online
thanks for your time
Last edit: 13 years 5 months ago by dvdf77.
13 years 5 months ago #106351 by nicolas
That link doesn't work either.
13 years 5 months ago #106352 by dvdf77
13 years 5 months ago #106357 by nicolas
このリンクは訪問できません。このエラ-が出ます:
13 years 5 months ago #106358 by nicolas
also, on the link desyou.com/en/collections-and-shop/jewelery/diamond.html there is no carousel.
Where is your carousel and what exactly doesn't work ?
Please provide more precise information, in japanese if needed. A screenshot of the problem could be helpful.
13 years 5 months ago #106362 by dvdf77
re-explain the whole
when active in the list view products in vertical slider and step on it with the mouse button to bring up the add to cart button does not add to cart the product, but opens the product page. this behavior does so only on IE and Safari ... on firefox all ok
I am attaching screen
13 years 5 months ago #106378 by nicolas
That's because you have the "link to product page" option of your products listing module turned on.
Turn it off and you won't be redirected to the product page.
13 years 5 months ago - 13 years 5 months ago #106381 by dvdf77
with this solution, I no longer have the ability to have the title with a link to the product page.
How can I have the link to the product on the title and not on the button?
13 years 5 months ago #106398 by nicolas
In that case, keep that option on and remove the line:
$htmlLink = 'onclick="window.location.href = \''.$link.'\'';
from the file "listing_slider_vertical" for the product view via the menu Display->Views
13 years 5 months ago #106402 by dvdf77
thanks I could not find that line
good for your assistance
Hikashop Pro is very very very good shops to create in a short time
Thank you for the beautiful work done but do not stop improving and never make us life more relaxed :P
best Regards
Time to create page: 0.126 seconds
