- Thank you received: 2
Enable carousel Module changes heighth at will
- miracleecho
13 years 4 months ago #108195
by miracleecho
Enable carousel Module changes heighth at will was created by miracleecho
We have a carousel configured that changes height at will. So when you refresh your screen it may be normal size, or large. I have attached images to show you along with module setup. Thanks.
13 years 4 months ago #108247
Replied by nicolas on topic Enable carousel Module changes heighth at will
You didn't set any thing in the height field of your module. So the images will resize for fit in the 250px width limit that you set while the height will be generated automatically based on the width and the proportion of the image.
If you want your images to have a fixed height in the carousel, then simply enter a value in the height field.
- miracleecho
13 years 4 months ago #109237
by miracleecho
Replied by miracleecho on topic Enable carousel Module changes heighth at will
That corrected it. Thanks.
