What is multi cart?
13 years 5 months ago #110692 by fan4chevy
What is multi cart and how do I set it up in business?
13 years 5 months ago #110709 by Mohamed Thelji
Replied by Mohamed Thelji on topic What is multi cart?
As it's said in the documentation :
Enable multi carts: The multi-carts allow the users to have many carts, by this way, they can create as cart as they want, and save them.
And you'll be able to enable it through the Enable multi carts of the "Hikashop->System->Configuration->'Feature'" page.
Hope this will help you.
13 years 5 months ago #110710 by Xavier
Replied by Xavier on topic What is multi cart?
A customer can have multiple carts, so he can bundle one, and come back later to retrieve his previous created cart.
To enable this feature, you just have to go in Configuration > Features and enable multi cart.
11 years 4 months ago #206933 by tbroderick
Replied by tbroderick on topic What is multi cart?
I have a client who has distributors in several countries. Each distributor needs to have their own cart and the orders separated by distributor so they can fulfill the orders for their own geo-areas. Would the multiple carts be used for this? Or, would a separate website with a different Hikashop install be needed?
Thanks for your help.
11 years 4 months ago #206936 by nicolas
Replied by nicolas on topic What is multi cart?
No, I think that in that case, you need HikaMarket Multivendor and have each distributor as a vendor. HikaMarket has the capability to assign different vendors to different areas like you need.
www.hikashop.com/extensions/hikamarket-multi-vendor.html
6 years 1 week ago #325991 by BluepointWebdesign
We have the market extension, but how dan we set it up so each vendor has his own shopping cart?
e.g. if a customer shops and put item 1, 3 and 4 of vendor A in his shopping cart. He decides to continue shopping, and see product 5, 7 and 8 of vendor B and puts it in the cart. But this may not be in 1 cart together but need two seperate carts one for vender A and B ect.
How can i configure that?
Hope you understand my question..
6 years 1 week ago #326023 by Jerome
Replied by Jerome on topic What is multi cart?
HikaMarket do have a feature to block products from another vendor to be added into the cart.
We start a feature to redirect the products to another carts but the result was disturbing for the customers who couldn't understand why the product was not in their cart and didn't see easily that they have different carts.
The "limit vendors in cart" setting is mandatory for that kind of configuration but the redirection of products into other carts is not something that I would recommend at the end.
www.hikashop.com/support/documentation/1...onfig_market_general
5 years 9 months ago #329883 by BluepointWebdesign
Is it possible, that when customer switches from vendor listing that his cart will empty automaticly?
e.g. when customer select 3 items of vendor A and when he goes to vendor B his cart will be emptied so in that way he see that he only can buy at one vendor at the time??
5 years 9 months ago - 5 years 9 months ago #329911 by Jerome
That's not something that I wouldn't recommend since it would have a lot of unwanted side effects and might be more frustrating for the customer than "life saving".
Switching the current cart depending the vendor page you're browsing could be an idea. But, for my point of view, clearing the cart would be worst for the customer than sending the product to a different cart.
Last edit: 5 years 9 months ago by Jerome. Reason: would => wouldn't
5 years 9 months ago #329923 by BluepointWebdesign
Oke,
But how can we set it then, that the customer goes to a cart only for that particular vendor, now all products stay in cart of vendor A but when looking at products of vendor B they can not put anything in the cart. ??
5 years 9 months ago #329972 by Jerome
We're open to suggestions to make the system better for the customers.
But cleaning the cart when the customer see the page of another vendor is too brutal.
5 years 9 months ago #329986 by BluepointWebdesign
I can understand that it is brutal to clean the cart switching vendor, but how can we make it possible that it cleans the cart ??
We need that function otherwise it is to confusing for our customers.
Hope you can help..
5 years 9 months ago #330029 by nicolas
Well, clearing the cart when the customer adds a product to the cart and it is from a vendor different than the products already in the cart could be done with the development of a custom plugin. You could do that by implementing the trigger onBeforeProductQuantityCheck(&$products, &$cart, &$options) in such a plugin and creating a new cart and replacing it in $cart
