Innovative Gateway plug-in & Setting Card Types
13 years 5 months ago #111306 by jazzmang
I need to set this so it only allows MasterCard and VISA.
I can set the images to display this but the select menu still contains AMEX and Diners.
I cannot find where I set these or any thing in the documentation for the plugin.
Is this set with a HikaShop's end or does it get it from the gateway's end somehow?
13 years 4 months ago #111400 by nicolas
It is set in the HikaShop innovative gateway plugin code:
$method->ask_cctype = array('visa' => 'VISA', 'mc' => 'MasterCard', 'amex' => 'American Express', 'diners' => 'Diners', 'discover' => 'Discover', 'jcb' => 'JCB' );
in the file plugins/hikashoppayment/innovativegateway/innovativegateway.php
You will have to remove it in the code directly via FTP of a file manager extension.
The following user(s) said Thank You: jazzmang
13 years 4 months ago #111656 by jazzmang
Exactly what I needed.
Might want to think about moving this to a variable like you have in a few other payment modules.
Mainly because we will have to remember to back and do this every time we perform an update to Hikashop as far as I can tell.
13 years 4 months ago #111660 by nicolas
Yes, we'll add that for next version.
13 years 4 months ago #114581 by jazzmang
FYI I was told by a client today trying to get Inuit to activate this on their account, and the client was told:
we are no longer opening Innovative Gateway merchant accounts because that service is being phased out. You will need to use a shopping cart that is compatible with "QuickBooks Merchant Service SDK" also known as "Intuit Merchant Service." The following page describes this service in more detail on section 2: kbgopayment.intuit.com/intuit/index?page..._content&id=INF20280
Thought I'd share.
Trust me, I'm not happy with Inuit right now. Back to recommending Authorize.net at the moment.
