Registration not showing up!
13 years 3 months ago #115615 by timmyjake97
I have the hikashop cart configured to show login and registration. It show the login part, but on registration it show only "Registration" but no place to register! Please help. I have Essential hikashop
13 years 3 months ago #115630 by Xavier
Replied by Xavier on topic Registration not showing up!
Thanks to give us a screenshot of your checkout configuration and a link to your website.
13 years 3 months ago #115732 by timmyjake97
Ok. The website wasn't fully up yet, but i put it online so you could take a look at it. is the url, but the problem with registration is with cart/checkout. Here is the screenshot. Ummm, sorry. I have Windows XP and don't know how to do the screenshot.
13 years 3 months ago #115733 by timmyjake97
Most of that probably didn't make sense. ;) Here is the url. victorianbeauty.net
13 years 3 months ago #115793 by Eliot
Replied by Eliot on topic Registration not showing up!
That's a strange bug.
Did you edited any view of the cart or checkout?
Are your custom fields still published?
Also we need this screenshot so just press the "print screen" key of your keyboard and past the result in paint ;)
13 years 3 months ago #116039 by timmyjake97
Sorry it took so long. I had some internet issues. :unsure: :unsure: Anyway, here are the snapshots. After you told me, it was like Duh!! This is my first website, so please understand if i seem a bit illiterate when it comes to them. Hmmm, i don't know. I forced a menu on checkout. Regristration menu, which didn't pop up. I don't think i changed any of the custom fields. If you would like, I can give you a login and password to the website administrator, so that you can see it for yourself.
13 years 3 months ago #116060 by nicolas
From what I can see your HikaShop settings are fine. Can you make sure that you didn't disable the registration in the Joomla user manager's options ?
13 years 3 months ago #116082 by timmyjake97
I am sorry, but i don't know where that would be! User Manager? Is that in Control Panel or configuration?
13 years 3 months ago #116083 by timmyjake97
Found it and it said that it was on.
13 years 3 months ago - 13 years 3 months ago #116181 by Mohamed Thelji
Did you check the Allow User Registration option through "Control panel->User manager->'Options'" ?
Last edit: 13 years 3 months ago by Mohamed Thelji.
13 years 3 months ago #116457 by timmyjake97
Yep, I did that. I didn't have to change anything, though. It was correct. :(
13 years 3 months ago #116635 by timmyjake97
Anything else that I could try?
13 years 3 months ago #116661 by Jerome
Replied by Jerome on topic Registration not showing up!
Is it possible to have a link to your website, so we can see the problem in the front-end, and if possible, check your configuration in the backend.
You can send us such private information (like some backend credentials) using private message.
Thanks,
13 years 3 months ago #116874 by nicolas
You have edited the file administrator/index.php?option=com_hikashop&ctrl=view&task=edit&id=0|mlabel|component|com_hikashop|user|registration.php and broek something in it. I've revert your changes and it's working fine again.
13 years 3 months ago #116876 by timmyjake97
Thanks, you guys are awesome. If I may just ask one more question of you. On my products page, I got rid of the border around them. Now I can't see the text because it is white. What can I do besides change the background color? (I already checked the text section of the template and all text is set to black) Thank you so much for you help! :woohoo:
13 years 3 months ago #116929 by Xavier
For the css questions you can read our tutorial on how to customize the display.
It describe how to find an element and where to edit it.
13 years 3 months ago #117026 by timmyjake97
Thanks for your help. It might take me a while to find it, there's a lot of css to go through and I'm not too good at it yet. But I will find it. Thanks again!!
Tim :cheer: B) :woohoo:
12 years 11 months ago #135963 by Littlefeather
Hi Guys (or Gals) ,
I have this problem, too. Registration and login not showing on front page of shop. Login Only shows after you order something and want to go to cart.
Hikashop essential
This is a new site as i am dumping Virtuemart. Building site under the old one. Still very new at this............
Have been lookng everywhere for answer but.....
site Front end - hatchersncatchers.com.au/ns1
12 years 11 months ago #135974 by nicolas
Your question is not related to the problem in that thread since the registration displays fine on the checkout on your website.
If you want to display a login/registration form on your website, like a login module for example, it's not HikaShop which handles that but Joomla. So you can for example publish the joomal login module via the joomla modules manager, or create new menu items of the type user registration form via the joomla menus manager.
12 years 11 months ago - 12 years 11 months ago #135987 by Littlefeather
Thank You however not sure I understand.
On the demo site of Hikashop there are two items on the left hand column ( Login and My Cart)
On my site (hatchersncatchers.com.au/ns1) a login form pops up when an item is purchased but does not show anywhere else for customer to log out as in the demo site.
Are you saying these have to be done through Joomla?
Are the login details then integrated through the hika shop?
There should also be a captcha that is not showing (captcha - Playthru) It is enabled in both Joomla and hikashop but not showing.
Okay! I got the cart to show when logged in as customer!!
Last edit: 12 years 11 months ago by Littlefeather. Reason: got part of answer
Time to create page: 0.128 seconds
