Registration not showing up!
12 years 11 months ago #136010 by Mohamed Thelji
1. Sure, if you don't want your customer to just login/register through the checkout, they will be able to login through a Joomla login module that you'll have to create.
2. I didn't really understood your question, but note that Hikashop use Joomla user, so everytime one of your customer will register, this will create a Joomla User which will be used by Hikashop.
3. If you want to use a captcha you should use the ReCaptcha on forms plugin
9 years 3 months ago #275923 by vadim_29
Can you tell me please how did you revert the code, i have the same issue, login, forgot password and forgot email works fine, but the register new user shows nothing. All the configuration are just like you said previously.
9 years 3 months ago #275931 by vadim_29
Hi Mohamed,
The post that contains:
You have edited the file administrator/index.php?option=com_hikashop&ctrl=view&task=edit&id=0|mlabel|component|com_hikashop|user|registration.php and broek something in it. I've revert your changes and it's working fine again.
I would like to know how did Nicolas resolved the issue.
Thank you!
9 years 3 months ago #275935 by vadim_29
Btw it is possible to have two register and login form, one for normal users and another for partners.When you create a new account, the normal can be activated by the user (receive an email with a link in it), but the partner should be only by admin. I only found the option that you only can choose between one of those.
Thank you again!
9 years 3 months ago #275933 by Jerome
Replied by Jerome on topic Registration not showing up!
That thread is 4 years old and we can't even know if you have the same issue.
For what I could see in the screenshot, I'm not so sure.
So please open a new thread and provide the requested information.
9 years 3 months ago #275985 by vadim_29
Hi Jerome,
Here you have the prints about my configuration in joomla global configuration and the hikashop config. If i didnt send all the items needed to resolve the isue, please tell me what should i send next.
My idea was to have an icon for login, not just in checkout, so i've created an icon as an image and redirected to hikashop login url. I dont want to use the joomla login.
Thank you!
9 years 3 months ago #275986 by Jerome
Thank you for the screenshot but unfortunately, you didn't do what I asked :
So please open that new thread for your issue.
And then you will be able to fill the form about your HikaShop version number, etc.
