pdf invoice plugin - an existing problem
13 years 2 months ago #124042 by innovoweb
If the billing and shipping address printed both, they are not aligned. The delivery address on the right side is a little above the billing address. How can I change this please?
This problem has been discussed more than a year ago. I bought the PDF invoice plugin now, and the problem is still present.
Then another question: The amounts below are centrally aligned, which is not very nice, can I change this so that the amounts are aligned to the right?
13 years 2 months ago #124084 by Xavier
You have to edit the file "attacinvoice/invoice.php" in the plugin attachinvoice, the pdf invoice template is in that file.
13 years 1 month ago #124464 by innovoweb
I know where I need to make the change, but it does not work! See also the link to the forum, I have changed the same way, no chance ...
www.hikashop.com/forum/4-how-to/66835-pd...questions.html#66835
Regard Esther
13 years 1 month ago - 13 years 1 month ago #124507 by Jerome
if(file_exists(HIKASHOP_MEDIA.'plugins'.DS.'invoice.php')){ $file = HIKASHOP_MEDIA.'plugins'.DS.'invoice.php'; }else{ $file = dirname(__FILE__).DS.'attachinvoice'.DS.'invoice.php'; }
The plugin checks the file "invoice.php" in the "media/com_hikashop/plugins/" folder and if there is no file, it will use the default "invoice.php" in the sub folder "attachinvoice" (in the plugin folder).
By modifying the file which is used by the plugin, you will change the result of the new generated PDF.
Last edit: 13 years 1 month ago by Jerome.
13 years 1 month ago #124538 by innovoweb
Thanks for your answer. Sorry, but I think we are not talking about the same thing. The problem I have is the same as that described in this link www.hikashop.com/forum/4-how-to/66835-pd...questions.html#66835 , (see also attachment)
I've followed all the suggestions for change, but unfortunately without success. Also commenting out the country fixed, does not work.
13 years 1 month ago #124668 by Xavier
Thanks to tell us exactly which file you are editing, and the modifications done.
We are talking about the same thing, and we are giving the same solution as the topic you gave.
So I think that there is something that is not done as it should.
13 years 1 month ago #125038 by innovoweb
I have changed in the ivoice.php at addressess td (padding-left), the number of 50 to 10 px. The two address fields are now on the same line.
I have also changed the attachinvoice.php so the PDF is sent to the first mail. This works, but now the invoice number is not displayed.
Where is the problem?
13 years 1 month ago #125060 by Xavier
It probably come from the changes made, can you give us the edited parts ?
Thanks to put them between the tags [ code] ... [/code] (without spaces).
13 years 1 month ago - 13 years 1 month ago #125077 by innovoweb
I replaced this line:
if(empty($data->mail_name) || empty($data->data->order_status) || $data->mail_name != 'order_status_notification' || $data->data->order_status != 'confirmed') return;
by the line:
if(empty($data->mail_name) || empty($data->data->order_status) || !in_array($data->mail_name,array('order_status_notification','order_creation_notification'))) return;
Last edit: 13 years 1 month ago by Jerome. Reason: adding [code] for code.
13 years 1 month ago #125131 by Jerome
The invoice number is generated when the order_status is "confirmed" or "shipped".
You can change this value in the HikaShop configuration. If you add the order status "created", the invoice number will be generate during the order creation (and will be displayed in the first email).
