- Thank you received: 6
Does JotCache work with Hikashop?
12 years 10 months ago - 12 years 10 months ago #137870
by cbadmin
Does JotCache work with Hikashop? was created by cbadmin
Has anyone succeeded to have JotCache working with Hikashop?
JotCache: extensions.joomla.org/extensions/core-en...formance/cache/13155
Hikashop: extensions.joomla.org/extensions/e-commerce/shopping-cart/14275
I am trying to exclude a module position where the shopping cart module is published but it does not work.
Shopping cart module is cached and therefore is not updated at page reload.
To discard potential incompatible 3rd party plugins and complex templates issues, I started from a clean installation with no extra addons.
Apache/2.2.24 with mod_fcgid/2.3.6 for the PHP interface
Joomla 3.2.1
Hikashop Business 2.2.3
JotCache 3.1.7
Template: Protostar 1.0
No caching functions besides JotCache
I tried the different ways suggested in JotCache manual but nothing works with Hikashop.
Any idea from the community?
Max
Joomla 3.2.1
JotCache 3.1.7
Max
Last edit: 12 years 10 months ago by cbadmin.
12 years 10 months ago #137893
Replied by nicolas on topic Does JotCache work with Hikashop?
Are you sure that the caching issue comes from the modules caching of JOTCache and not from another caching like the JOTCache page caching, or Joomla's caching plugin or Joomla's configuration caching ?
I don't see why it would behave differently for HikaShop modules than other modules since all the HikaShop cart module does is that it displays the HTML of the module, like any other module. You might want to ask JOTCache support as they know better than us how to configure JOTCache than us.
12 years 10 months ago #137966
by cbadmin
Replied by cbadmin on topic Does JotCache work with Hikashop?
Yes as mentioned previously
- Global cache is OFF
- All cache related system plugins are OFF, except JotCache obviously
We are hosting our 300+ products Hikashop site on a Cloud plan of SiteGround and we are still at 13 seconds per page (6 seconds coming from Joomla).
All optimizations are already done (HTML/JS/CSS minifying/compiling, Page Speed/YSow scores maximization, CDN).
JotCache brings the 6 seconds from back-end down to 1 second. Very impressive but it caches the shopping cart.
This request for feedback was posted first in the JotCache forum and will appear here after moderator's validation
www.jotcomponents.net/forum/8-jotcache-c...er-joomla-extensions
We will share what we learn there, but maybe here others have experience to share as well.
12 years 9 months ago - 12 years 9 months ago #139060
by cbadmin
Replied by cbadmin on topic Does JotCache work with Hikashop? YES IT DOES!
The developer of JotCache has just released the 3.1.9 which works with Joomla 3.2 and which can successfully exclude module positions from caching.
If you are using optimization plugins such as JCH, jbetolo or similar, remember to deactivate any HTML minifier as it is not compatible with JotCache.
So with JotCache you can drastically speed up your Hiksahop site and keep the Shopping Cart not cached in a specific module position excluded from caching.
This is awesome!
You can get it here www.jotcomponents.net/web-programming/jo...cache-download-3-1-2
PS: there is still a problem if your site uses multiple currencies as they will be cached. I will report later if I find a way to solve that.
This is awesome!
Last edit: 12 years 9 months ago by cbadmin.
- Thank you received: 1778
12 years 9 months ago #139075
by Mohamed Thelji
Replied by Mohamed Thelji on topic Does JotCache work with Hikashop?
Thanks for your feedback
