Front-End Optimization Issue
12 years 9 months ago #141884 by albertwilson
We are using the jbetolo plugin for front-end optimization on our website (site load times in 0.8 - 1.2 seconds :cheer: ). However, the product rating stars are not showing when we merge javascript (attached example). The javascript merging is giving us our best performance gains, so we'd like to be able to use it.
I'm wondering what I need to exclude from being merged, or what load order of the js I need for the rating stars to properly display. Or, perhaps there is an alternate workaround?
Also, hikashop is awesome and the perfect solution for us, cheers to a great product!
-- url of the page with the problem -- : our dev environment is at cocaineusa.com
-- HikaShop version -- : 2.2.3 Business
-- Joomla version -- : 3.2.1
-- PHP version -- : 5.4.23
-- jbetolo version --: 2.5.0.44e92e4
Thanks,
Albert
12 years 9 months ago #141983 by nicolas
Yes you need to exclude the javascript of HikaShop from being merged together. Then it should work fine.
The following user(s) said Thank You: albertwilson
12 years 8 months ago #148154 by albertwilson
I've finally found the fix and issue, if anyone else is having problems with java optimizations. It was deferring the javascript, which caused the issue. Everything else works fine minified and compressed, it just can't be set to defer.
