Help with backend CSS
- rjohnson1990
12 years 7 months ago - 12 years 7 months ago #149191
by rjohnson1990
Help with backend CSS was created by rjohnson1990
I'm new to the HikaShop forums. This is the first time I have ran into an issue with HikaShop. I was trying to change the style on my front end but accidentally changed my Back-end CSS File from None to Default. When I did, my back-end looked like this:
After I made this mistake, I changed it back to None so it should look like this:
Once I leave the configuration page and go back in again, it looks like the first image. How can I get it so it stays looking like the second image?
Last edit: 12 years 7 months ago by Jerome.
12 years 7 months ago #149224
by Jerome
Replied by Jerome on topic Help with backend CSS
I removed your images which didn't work.
Please use the HikaShop system or a more appropriate website for hosting your images.
- rjohnson1990
12 years 7 months ago #149273
by rjohnson1990
Replied by rjohnson1990 on topic Help with backend CSS
12 years 7 months ago #149327
Replied by nicolas on topic Help with backend CSS
Normally, you should get that look with the "default" CSS backend file.
So it's the default one you should always use for the backend.
If you don't get the correct display with the default CSS, it would indicate that the file has been altered manually. In that case, you should download the HikaShop install package and copy the file media/css/backend_default.css form the package to your website media/css/backend_default.css file.
- rjohnson1990
12 years 7 months ago #149356
by rjohnson1990
Thank you for the reply. I have it fixed now. Before, setting it as default didn't show the default back-end layout. Now it is working.
