Download Products with a required contactorm
12 years 6 months ago #153512
by jeroenvd
Download Products with a required contactorm was created by jeroenvd
Hi!
I'm not sure if it is here yet, or it can be done with the default HikaShop but i would like the Digital Downloads only to be available, after people filled in a contactform.
So i know who downloaded it, and can used that information later on.
Is this possible within HikaShop or should i use a 3rd party extension?
Regards!
Regards!
12 years 6 months ago #153521
by Xavier
Replied by Xavier on topic Download Products with a required contactorm
This is possible in HikaShop.
When installing, in the Wizard options select that you want to sell virtual products, that will set default configurations for that.
Then create product with files attached, then the customer must buy the product and his informations are asked in the checkout, the complete address etc.
12 years 6 months ago #153611
by jeroenvd
Replied by jeroenvd on topic Download Products with a required contactorm
Hi Xavier,
Thank you for your reponse.
However, what if i already installed HikaShop?
Can't found this option now.
12 years 6 months ago #153623
Replied by nicolas on topic Download Products with a required contactorm
In that case, just make sure that the "force shipping regardless of weight" option is turned off in your HikaShop configuration.
