Pre Order Question re product options/attributes
12 years 5 months ago #157551 by davidmayne
I have many products with the same option/attribute (drop down with many values) that can be selected which will modify the total price. This option/attribute has the same price for many different products. Can I do this within HikaShop and the attribute values modified in only one place and not on a per product basis? Within one shop I tried I was able to add a created attibute to a product via a drop down list that did something similar.
Thanks,
David.
12 years 5 months ago #157559 by Mohamed Thelji
Hi David,
Note that to do what you want, the solution will be to :
- Use characteristics
OR
- Add options through the "options" tab of your product configuration page.
