- Thank you received: 2
cart module code prevents module from being shown
12 years 4 months ago #161621
by Hans987
cart module code prevents module from being shown was created by Hans987
HIka version 2-1-3
I have a problem with the modified code of my cart module (html/com_hikashop/product/cart.php). If I use this modified code, the module contains no html on every non-product pages. On product pages, it works.
If I use no file "cart.php" in the product folder or use an older file, everything is OK.
I can't figure out, which part of the module code erases the complete cart html code, the outer divs should be shown always, right?
Please help!
Please help!
12 years 4 months ago #161636
Replied by nicolas on topic cart module code prevents module from being shown
I think it's that line:
if ($jinput->get('option', 'default_value', 'filter')=="com_hikashop"){
That if will only run the code inside it if the current component page is a HikaShop page.
The following user(s) said Thank You: Hans987
Time to create page: 0.041 seconds
