- Thank you received: 3
Right side article options is too small (backend)
11 years 9 months ago #187953
by miracle
Right side article options is too small (backend) was created by miracle
-- Joomla version -- : 2.5.28
Hi, when I edit an article in the backend there's a left side and a right side, the right side containing all the options, characteristics, prices, et cetera. This site is very small, which causes for example the prices to be badly visible. The left side is 70% (I see it in the code) and in our case way too width. Is there a way to make this more in balance. Is there a line of CSS I could put in my custom css of the template or so that will change the left side to 60%. Or is there another solution?
11 years 9 months ago #187975
by Jerome
Replied by Jerome on topic Right side article options is too small (backend)
For the moment you can use custom css or view override but the product edition in the HikaShop backend will evolve in a future release in order to integrate the interface introduced in HikaMarket.
11 years 9 months ago #188037
by miracle
Replied by miracle on topic Right side article options is too small (backend)
Any idea which CSS code I need to use to get that done (while waiting for the new version)?
11 years 9 months ago #188045
Replied by nicolas on topic Right side article options is too small (backend)
The simplest would be to edit the file "form" of the view "product" via the menu Display>Views and change the line:
<td width="70%" valign="top">
<td width="50%" valign="top">
Also, note that if you upgrade to Joomla 3, the left and right areas would actually have the same width by default without changing anything.
