W3C HTML5 Validation problem
11 years 7 months ago #197630 by LukeDouglas
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.4.33
-- Browser(s) name and version -- : Multiple
-- Error-message(debug-mod must be tuned on) -- : Errors found while checking this document as HTML5!
baylissgallery.com
On the W3C validation for BaylissGallery.com ( W3C Validation Link ), we are getting an iframe error on the HikaShop Content Module for the Featured Product.
Could you implement HTML5 compliant changes in your next update?
Here is the error message:
Error Line 715, Column 190: Bad value {handler: 'iframe',size: {x: 480, y: 140}} for attribute rel on element a: The string {handler: is not a registered keyword. <div class="hikashop_container"> Syntax of list of link-type keywords: A whitespace-separated list of link types, with no duplicate keywords in the list. Each link type must be listed as allowed on <a> and <area> in the HTML specification, or must be listed as allowed on <a> and <area> on the Microformats wiki, or must be an absolute URL. You can register link types on the Microformats wiki yourself. Error Line 715, Column 370: Bad value {handler: 'iframe',size: {x: 480, y: 140}} for attribute rel on element a: The string {handler: is not a registered keyword. <div class="hikashop_container"> Syntax of list of link-type keywords: A whitespace-separated list of link types, with no duplicate keywords in the list. Each link type must be listed as allowed on <a> and <area> in the HTML specification, or must be listed as allowed on <a> and <area> on the Microformats wiki, or must be an absolute URL. You can register link types on the Microformats wiki yourself.
11 years 7 months ago #197638 by Jerome
Replied by Jerome on topic W3C HTML5 Validation problem
I am sorry but for the errors you got ; we can't.
The "rel handler" you have is the mootools lightbox system which is provided by Joomla itself.
You can see to switch to another lightbox system for your popup and your image popup (like "bootstrap" and "shadowbox") but you have to be sure that your template it compatible with.
11 years 7 months ago #197713 by LukeDouglas
Jerome,
I installed Mootools Enabler / Disabler and enabled all disabling of Mootools but that didn't work. Any other suggestions?
Luke
11 years 7 months ago #197763 by LukeDouglas
Jermone,
One of the Joomla admins stated this:
The possible "a rel" values are listed here: www.w3schools.com/tags/att_a_rel.asp
Hikashop is using this value: "{handler: 'iframe',size: {x: 480, y: 140}}"
This has nothing to do with MooTools, it's a problem with Hikashop. They just shouldn't assign this value to "rel".
A workaround would be to modify Hikashop's core to address this problem.
11 years 7 months ago #197769 by Jerome
I never wrote that it was mootools, but I wrote it was "mootools lightbox system" ; it means that it is a lightbox system which use mootools.
There is a nuance which had his importance.
So, if you read the rest of my message, I wrote that you have to use another popup system in HikaShop.
Please follow my indications.
The mootools modal (SqueezeBox) is provided by the javascript file "/media/system/js/modal.js" and is available since Joomla 1.5 and is still available in Joomla 3.4.
The only (and unique) way to use that SqueezeBox is to put a rel on a "a" link.
The other solution is to use another popup system ; like I suggested you in my previous message.
API Joomla for JHTML::_('behavior.modal')
api.joomla.org/cms-3/classes/JHtmlBehavior.html#method_modal
More details about the API of behavior.modal
api.joomla.fr/joomla25/d1/d74/classJHtml...5128b86e49164b9b7a5d
Example of use of modal in Joomla from docs.joomla website:
docs.joomla.org/Creating_a_modal_form_field
11 years 7 months ago #197793 by LukeDouglas
OK, I understand what you are saying now.
So I have edited the configuration for the display to use a different popup mode.
However, I am still getting the same validation errors. Am I missing something?
Luke
11 years 7 months ago #197811 by nicolas
The notice popup of the add to cart buttons always use the mootools popup system for now even if you change that setting.
In order to avoid that, you would have to change the "when a product is added to the cart" option of the HikaShop configuration so that it doesn't display the notice popup.
And that will remove that warning from the w3c validator.
Note that it is not because the w3c validator says that it is not valid that it means that it is a problem. The rel attribute used by the mootools popup system has been used a whole decade on many websites and works fine, and doesn't create any problem.
11 years 7 months ago #197931 by LukeDouglas
Nicholas,
I looked at all of the configuration options but could not find the "when a product is added to the cart" or I might be blind. Which configuration tab is it under?
Also, I know that websites work just find that do not validate correctly as I've used validation for well over a decade. However, I do have some clients that 'require' that their sites validate. I don't want to close a client because of this issue. ;)
Luke
11 years 7 months ago #197955 by nicolas
The exact name is "After a product is added to the cart". It's in the main tab.
11 years 7 months ago #198077 by LukeDouglas
Nicholas,
Well no wonder I couldn't see it. It's not there and I do have the current Hikashop version 2.4.0. Any ideas?
11 years 7 months ago #198080 by Jerome
Please read carefully the Nicolas' message.
hint : you're not in the right tab.
11 years 7 months ago #198198 by LukeDouglas
OK, I found it. It was actually in the 'Cart' section of the 'Main' tab. It was not set to "Stay and display a popup notice" anyway. It was set to "Always go to the checkout". I changed it to "Always stay on the same page" but that didn't fix the problem.
Any other ideas?
11 years 7 months ago #198232 by nicolas
I see that the code was changed in the add to cart system in order to fix something else which changed that behavior.
Change the line:
if($redirect=='ask_user' || hikashop_loadUser() == null){
if($redirect=='ask_user'){
in the file administrator/components/com_hikashop/helpers/cart.php and that will remove that.
11 years 7 months ago #198277 by LukeDouglas
Nicholas,
That fixed it! Thanks.
However, you indicated that the code was original changed to fix something else. Would changing this code re-create a problem that the original code fixed? I would much rather have a 'validation' problem than to break the shopping cart from functioning properly.
Luke
11 years 7 months ago #198310 by Jerome
The commit that Nicolas pointed include several modifications and that specific modification might not be kept.
So I think that the revert that Nicolas wrote will be include in the next HikaShop release.
11 years 5 months ago #203184 by bdthemes
Hello hikashop guys, why you not use any other lightbox system for it? it will be a good decision if you use any others lightbox plugin.
11 years 5 months ago #203190 by Jerome
We are not opposed to, and we are already proposing "shadowbox" in the image lightbox systems :)
But if you have good solutions for the "content" popup system we are open to suggestions.
11 years 5 months ago #203518 by bdthemes
use magnefic popup or something like it: dimsemenov.com/plugins/magnific-popup/
Time to create page: 0.123 seconds
