problem with menu in Isis template
11 years 4 months ago #205891
by pymgym
problem with menu in Isis template was created by pymgym
-- Joomla version -- : 3.4.1
Recently I upgraded (successfully at last) my site from joomla 2.5 to 3.4.1.
But I have a problem with isis template. The menu below tabs position is fixed in my backend. I send you 2 screenshots (#1 - #2).
I looked for a solution in forum and found it but the option "menu position" in general display options don't display in my backend (I send you another screenshot - #3)
Thanks you in advance for your help.
11 years 4 months ago #205904
by Jerome
Replied by Jerome on topic problem with menu in Isis template
Please check the backend CSS file that you are using.
It looks like you do not have the "default" one which contains CSS rules for the configuration sub menu.
The following user(s) said Thank You: pymgym
11 years 4 months ago #205973
by pymgym
Replied by pymgym on topic problem with menu in Isis template
:oops: :oops:
Fixed. Thanks.
I was using a custom CSS file in the backend (but I don't know why I changed it :S )
Fixed. Thanks.
