not sure HikaShop will solve my problem - help!
- Vlad Ghitulescu
11 years 4 months ago #208775
by Vlad Ghitulescu
not sure HikaShop will solve my problem - help! was created by Vlad Ghitulescu
Hello!
I have a rather general question but it seams that Joomla + HikaShop could be my solution, so I would really apreciate if you could give me an advice.
My job is to build a site for a company that makes doors.
The desired workflow will look like this:
1.- A customer chooses one of the doors and saves it to a "shopping cart" together with some notes (like the dimensions etc.).
2.- After this the customer might search for another door-type, chooses one and adds it to the "shopping cart" (with another set of notes). This step repeats optionally.
3.- After one (or many) choosen door, the customer decides to place an order, so he will have to fill out a form with the name, e-mail etc. AND the choosen doors & notes from the shopping cart and sends this to the door-company.
IMPORTANT: The whole process ends when the customer sends this form (and not - as usual - when he pays). After this he will be called by the door-company for further specifications etc.
All of the sites I did so far were static & built with Bootstrap (whith or without LESS).
I suspect that a static site is not possible now, that's why I thought of Joomla and started to look for Joomla-extensions - and so I discovered the HikaShop component.
Would it be possible to achieve my goal with Joomla + HikaShop?
And if so: Would it be something I can do (as my very first Joomla-project!)?
Thanks in advance!
Vlad
Thanks in advance!
Vlad
11 years 4 months ago #208777
Replied by nicolas on topic not sure HikaShop will solve my problem - help!
Yes, no problem to do that with HikaShop.
It will however require the Business edition so that you can create custom fields of the table "item" via the menu display>custom fields in order to get the notes from the customers for each product.
The following user(s) said Thank You: Vlad Ghitulescu
- Vlad Ghitulescu
11 years 4 months ago #208814
by Vlad Ghitulescu
Replied by Vlad Ghitulescu on topic not sure HikaShop will solve my problem - help!
Hi, nicolas!
Thanks for your quick reply!
That's good news! I will definitely consider Joomla & HIkaShop when the whole project comes to life.
Thanks again!
Vlad
Thanks again!
Vlad
