“Stay and display a popup notice” 404 error
11 years 2 months ago #212979 by telarian
-- url of the page with the problem -- : www.woodbender.co.za/
-- HikaShop version -- : 1508041003
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.6.9
-- Browser(s) name and version -- : All browsers
We are currently experiencing a problem with the “Stay and display a popup notice” function.
Currently we have two copies of the same site:
A. www.woodbender.co.za/ and B. www.woodbender.co.za/vertex/
Site B was created as a backup copy before upgrading Hikashop to the latest version.
The difference between the two sites is that site A has Hikashop (1508041003) and site B has Hikashop (1407241754). On site A we have also added some SEO functionality.
Currently the “Stay and display a popup notice” is working properly on site B but on site A it returns an 404 error.
I have already looked at the other forum posts that deal with this issue but cannot find a solution to the problem. We have also disabled all the SEO optimisation but still the problem occurs on site A.
Can you please assist us in resolving this issue? Please note that we have now disabled this function on site A.
I can provide you with login credential for both the site.
11 years 2 months ago #212999 by lousyfool
Site B is using a pretty dated HikaShop version, obviously, and possibly an older Joomla version as well, so it works there, but you can't really compare with site A.
Anyhow, there are other threads on the issue, and here is one, for example: www.hikashop.com/forum/checkout/878989-4...-adding-to-cart.html
You see that the issue was taken care of by a "hot fix" since your HikaShop 2.5.0 build. So, download the very latest & greatest, install it over your current one, and the issue should be fixed.
11 years 2 months ago - 11 years 2 months ago #212983 by nicolas
Please try to replace the file components/com_hikashop/router.php with the one in this archive.
Last edit: 11 years 2 months ago by nicolas.
11 years 2 months ago #213024 by telarian
Lousyfool, Nicolas
I installed the latest release as lousyfool suggested and the issue was resolved.
Many thanks
Stephan
Time to create page: 0.106 seconds
