Do I Need HikaShop StyIes with JSN Glass Pro?
11 years 2 weeks ago - 11 years 2 weeks ago #219419 by Jamiesea
-- Joomla version -- : 3.4
-- Browser(s) name and version -- : firefox 41.0.2
I'm looking at using JSN Glass Pro for my HikaShop and was wondering if I needed to use your HikaShop Styles with it or would the
JSN Glass Pro work fine without them?
Thanks!
Last edit: 11 years 2 weeks ago by Jamiesea.
11 years 2 weeks ago #219423 by nicolas
If you're using that template, you normally deactivate the styles of HikaShop and only use the styles of the template.
It's the template we would recommend as we're using it on our own demo website and as you can see there, it works fine.
But most of the templates listed in the "templates for hikashop" menu of our website, or bootstrap2 templates should work just fine without using styles.
Styles should actually be used when the template isn't made for HikaShop and you want to made HikaShop's look closer to the template.
