- Thank you received: 77
Validation not required custom field
10 years 10 months ago #224815
by almika
Validation not required custom field was created by almika
-- Joomla version -- : 3.4.6
Hi!
I can't get a solution after looking this forum. I need your advice.
I have an user custom field (text type) for the Hikashop registration form. It is not required, it may be empty.
But, if it is not empty I want to validate it.
I wrote regexp for it, but now regexp validation has not effect for not required custom field.
What can I do to resolve my issue?
Thank you
Hi!
Thank you
10 years 10 months ago #224862
Replied by nicolas on topic Validation not required custom field
Ah yes, the regex check is only usable if the field is required due to the way the system is made.
The simplest would be to create a first custom field with a yes/no choice and have the second field's "display limited to" option set to only display if the first field is set to yes.
That way, the user can say if he wants to fill the second field or not thanks to the first field and that way the regex on the second field would only apply if the yes choice would be selected in the first field.
10 years 10 months ago #224941
by almika
Replied by almika on topic Validation not required custom field
Thank you, nicolas
But it's not fit to me.
I want to do simple "honey pot", it is more friendly for users than captcha.
I think it will be good to do validation for not required fields, if the regexp exists for it.
What's the file I have to edit?
10 years 10 months ago #224966
by Jerome
Replied by Jerome on topic Validation not required custom field
The file to edit is the HikaShop field class
"administrator/components/com_hikashop/classes/field.php".
But I have to warn you that this file is a core file ; which means that you will loose your modification when you will update HikaShop.
