work with SSL
10 years 4 months ago #243085 by french150
work with SSL was created by french150
Hi. My site has the SSL certificate. Something to set?
Best regards
10 years 4 months ago #243094 by Mohamed Thelji
Replied by Mohamed Thelji on topic work with SSL
The best solution will probably be to use the "Force SSL on Checkout" option via "Hikashop->System->Configuration->Checkout" :
Force SSL on Checkout : This option will force HTTPS on the checkout pages. You need to have HTTPS configured and a valid SSL certificate before you can activate this option, otherwise the checkout will appear as broken and this option will be deactivated by the system. You will have to ask your hosting provider about how to setup HTTPS and obtain a valid certificate for your website. (since 1.0.6)
10 years 4 months ago #243157 by french150
Replied by french150 on topic work with SSL
I did that.
Best regards
