Products must be ordered in groups of 12
8 years 11 months ago #282414 by stefanfrei
is it possible to buy products (wine) only in groups of 12? So that always a box must be full to finalise order.
The Bottles are shipped in Boxes to 12.
Thanks,
Stefan
8 years 11 months ago #282416 by Mohamed Thelji
Hello Stefan,
There's actually no option to do that so, a solution can eventually be to directly sell boxes of wine instead of bottles.
8 years 11 months ago #282597 by stefanfrei
Thanks for answer. seling boxes is not possible because customers want to mix wines.
Is it possible to show only a message wich says that the box isnt full yet?
8 years 11 months ago #282601 by Mohamed Thelji
Sure, in that case the solution will be to directly do it using shipping methods, to do that you'll have to :
- Set the weight of every wine products to 1 kg for example
- Create a new via "Hikashop->System->Shipping methods"
- Set the "Minimum weight" and "Maximum weight" options to 12 kg
Repeat that step for order which will weight 24, 36, 48, 50, 62, ... kg so that your customers will only be able to finalize their orders if they have bought multiple
