Shopping Cart Module for Header
1 year 8 months ago - 1 year 8 months ago #365759 by Rusty
Hi!
I tried HikaShop for the first time. Overall it's great and accessible. Nice work! B)
But I miss a module for the shopping cart view in the website header. I talk about a "default" feature like a summarized "mini cart" that displays a small symbol with amount and value of the cart in the header, what the customer can click to reach the full view of the cart (site). I attached an example image.
Is there any module but I oversaw it?
If not: I would really appreciate it, if you could add such a feature (module). I think this is very usual. ;)
P.S. Okay, it's "fixed"! I found the configuration options. All fine! Works! ;)
Last edit: 1 year 8 months ago by Rusty.
1 year 8 months ago #365761 by oxido
You can do that.
In joomla go to modules, create a Hikashop Cart Module and make the settings you can see in my screenshot.
Make the module to be visible in what possition you want.
After that, go to hikashop > system > configuration > Language tab
And in your language translate / override this 2 lines:
X_ITEMS_FOR_X=" %s - %s y"
X_ITEM_FOR_X=" %s - %s x"
The result is what you see in my image, if you click on that "2 - 200 RON" you are redirected to the cart.
You can make it look even nicer you combine this with a dropdown menu if you use mega menu module or something else.
Have fun!
1 year 8 months ago #365762 by Rusty
oxido wrote: You can do that.
Yeah, maybe that would be possible. But it is way to complicated since HikaShop offers all options in the module configuration.
1 year 8 months ago #365763 by oxido
What is to complicated? This is how Hikashop works, you need to set Hikashop Cart Module and do the settings you saw in my screenshot.
If you have already a cart module, change the setings in that one and override the 2 lines in hika language.
I can set that cart for you In 2 minutes, I don't understand why you say is to complicated. I saw that Hikashop is someting new for you, but joomla also?
1 year 8 months ago #365765 by Rusty
oxido wrote: ... and do the settings you saw in my screenshot.
Oh my goodness! :whistle: I didn't look at your screenshots! But ... this is exact the way I did it, after I found it. ;)
