Problem with sef
1 year 1 month ago #368687 by Rusty
Problem with sef was created by Rusty
-- HikaShop version -- : 6.1
-- Joomla version -- : 5.3.x
-- PHP version -- : 8.4.x
Hi!
I have a problem in my production ready shop system. I faced an issue with the sef system.
What happens?
If I click from the homepage into the cart, the URL to the checkout (from cart view) looks like this: www.domain.com/checkout/chechout/ - it doubles the "checkout".
If I click from a category or product page into the cart, the URL to the checkout (from cart view) looks like this: www.domain.com/product/chechout/ - every following step contains the product name in the url.
I think this is not so good. ;)
1 year 1 month ago - 1 year 1 month ago #368690 by nicolas
Replied by nicolas on topic Problem with sef
If you haven't done it already, create a menu item of the type "HikaShop checkout".
Go to the HikaShop configuration page.
There, under the "Checkout" tab, you can select your HikaShop checkout menu item in the "Force a menu on checkout" setting:
www.hikashop.com/support/documentation/5...ml#checkout_checkout
This way, this menu item will always be used for the checkout, and there will be only one URL to access it.
Last edit: 1 year 1 month ago by nicolas.
1 year 1 month ago #368692 by Rusty
Replied by Rusty on topic Problem with sef
nicolas wrote: If you haven't done it already, create a menu item of the type "HikaShop checkout".
I already did!
1 year 1 month ago - 1 year 1 month ago #368697 by nicolas
Mmm. I checked your website, but I don't see what you described in your first message.
On your homepage, if I look at the "Zur Kasse" button of the cart module, the link is /warenkorb/checkout
On your website, if I go to the menu item "Figuren > Waldifiguren" I get the URL /figuren/waldfiguren
There, the URL of the "Zur Kasse" button of the cart module is still /warenkorb/checkout
And if I open the page of a product, like /figuren/geschnitzter-holzfaeller-serie-7cm , the URL of the "Zur Kasse" button of the cart module is still /warenkorb/checkout
So the URL to access the checkout is consistent everywhere I could check on your website and it doesn't double "checkout".
So, I'm not sure what to tell you. Maybe I didn't understand what your problem is. If so, could you please try to explain again what the problem is ?
1 year 1 month ago #368710 by Rusty
I'M sorry! I translated "warenkorb" into "checkout", so this confuses you.
I created the mentioned menu (type hikashop cart) -> named as "warenkorb". Then - in the cart and checkout - the url is shown as "warenkorb" (the menu) AND "checkout" - if I understand it right, this should not happen.
But you're right, if I open the cart right from a product page there's no more wrong url. Not sure how this was fixed ... :blink:
1 year 1 month ago #368713 by nicolas
In the HikaShop configuration page, you have the "Checkout SEF name" setting to manage the second "checkout" text in the URL of the checkout. What do you have in there ?
Do you have the text "checkout" maybe ? What if you empty that setting ?
1 year 1 month ago #368716 by Rusty
nicolas wrote: What do you have in there ?
It's already empty.
1 year 1 month ago - 1 year 1 month ago #368718 by nicolas
I think the issue might come from a detail you missed.
I said you create a menu item of the type HikaShop Checkout, but it seems you created a menu item of the type HikaShop Cart.
In that case, HikaShop has to add the "checkout" part at the end in order to display the checkout, not the cart page.
Change the menu item type to HikaShop Checkout and it should produce the URL you want.
1 year 3 weeks ago #368746 by Rusty
nicolas wrote: I think the issue might come from a detail you missed.
Ah, yes! That's it! :lol: Thanks!
But ... this menu item is marked as "legacy". So the use is not the best way I guess.
1 year 3 weeks ago #368749 by nicolas
You should normally find both:
i.imgur.com/jnjlbR6.png
If you don't see the "Checkout" one, it means that you have a translation override on the translation key used there.
Time to create page: 0.256 seconds
