Module to Show each Vendors Products on their Link
13 years 10 months ago #83711 by dsautelet
I have been trying to figure out a way to show the vendors products on their page when someone clicks on their name. I was trying this by making each vendor a category (ID) but even if I could get it to work, it would get extensive if you have many vendors. A simple vendor product module that shows only items from that vendor might work? The module could use the vendors ID so all products from that ID would be listed on their page.
13 years 10 months ago #83769 by Jerome
For the moment, the vendor page is not very flexible.
We are working on it in order to have the possibility to assign modules to the vendor page.
So it would be possible to list vendor products (or vendor categories+products) with a high configuration flexibility.
13 years 10 months ago #84107 by master_b
i think its must look something like Vendor=Manufacturer=Vendor all items
13 years 10 months ago #84120 by Jerome
I don't understand what "vendor=manufacturer=vendor all items" means.
13 years 10 months ago #84157 by master_b
when you click on vendor info you can see all him items like "manufacturer"
example: you open info some vendor and want see all him items for that we use vendor_id like in manufacturer filter we open for example Sony where see TV,Laptops,Cameras etc
13 years 9 months ago #84589 by Jerome
I just notice that I put your request in the TODO list but I didn't reply here.
So, I have put your ideas in the updates for the vendor page. We would see how we would be able to improve it !
Thanks,
