Vendor's 'My Products' page - products download
11 years 4 months ago #207702 by maujbigo
-- HikaMarket version -- : 2.3.4
-- Joomla version -- : 2.4.3
I tried to run without it but I really need the vendors to be able to download all their products in a csv file.
I know this is not present in Hikamarket at the moment, but is there any way to achieve this? Just download, NO need to upload csv.
If too complex to explain over the forum, is there any of your services provider you would recommend for this service?
11 years 4 months ago #207730 by Jerome
It really depends on what you want to export exactly.
Because you could have an "hard coded" export, where you will export just the columns you want.
Implementing that feature in HikaMarket needs to be flexible according to the vendor rights, so if he does not have access to a field, that field/information should not be exported (and the same for the import).
The HikaShop product export is working good but it export all possible content (categories, product, custom fields... Every available information).
Most of the content is easily available in the HikaShop view "product | export".
The rest is in the "administrator/component/com_hikashop/views/order/view.html.php", for the function "export".
function export(){ $product = hikashop_get('class.product'); $products = JRequest::getVar( 'cid', array(), '', 'array' ); $product->getProducts($products,'object'); $products =& $product->all_products; /* ... */
PS : I'm sorry but HikaMarket 2.3.4 does not exist.
11 years 4 months ago #208460 by maujbigo
Hi Jerome,
Thanks for that.
Really all I need to export are the products that are listed in the 'My Products' page for each vendor.
Just so each vendor can download a complete list of their products.
Is it something you would do as a paid customization?
If not, is there anyone you would recommend for this?
11 years 4 months ago #208468 by Jerome
I know that you want to export the products but which fields you want to export ?
It is something which could be done as a paid customization but you need to have some complete specifications.
What I can recommend you is the "commercial jobs" section of the forum or to contact some of the HikaShop partners.
The following user(s) said Thank You: PolishedGeek
10 years 9 months ago #230200 by filiar
Hi, Jerome
we also need such feature but in backend.
Is there a way to export one vendor's products from administration? I did not find how to filter products by vendor.
Regards!
10 years 9 months ago #230208 by Jerome
You're right, there is no "vendor" filter display in the HikaShop backend product listing.
HikaShop allow plugins to extend the filters and add their own ; so it would be possible for HikaMarket to add such kind of filter, like it is already done in the order listing for example.
It's something I can add in the TODO list.
Currently, you can see all vendor products in the backend when you display the vendor edition page.
In the "statistics" tab, you see a list of products and you have the "see all" button which give you a complete list.
But that listing is made directly in HikaMarket and not in HikaShop ; so there is no "export" button or other filters (category, type, etc).
10 years 9 months ago - 10 years 9 months ago #230264 by filiar
Hi, it's the exact place I thought such export button should be present.
Last edit: 10 years 9 months ago by filiar.
