Products duplicated in Vendor Control Panel
10 years 11 months ago - 10 years 11 months ago #224116 by trevsmiff
-- HikaMarket version -- : 1.6.7
-- Joomla version -- : 3.4.5
-- PHP version -- : 5.4.29
When products have options they are duplicated in the order product list in the vendor control panel:
Product list in the vendor control panel
Product list for the same order in the hikashop back end admin
The invoice is correct:
regards
Trevor
** Update ***
I have just tested this on another site (off-line) and the results are the same.
Last edit: 10 years 11 months ago by trevsmiff.
10 years 11 months ago - 10 years 11 months ago #224125 by Jerome
Thanks for the report.
In the file "components/com_hikamarket/views/ordermarket/view.html.php" please remove the code
if($options) { foreach($products as &$product) { if(!empty($product['product'])) $order->products[] = $product['product']; if(!empty($product['options'])) { foreach($product['options'] as &$opt) { $order->products[] = $opt; } unset($opt); } } unset($product); }
That block of code has been modified with the new design for the vendor order and has introduced that issue.
I'm working on the new order design for the main vendor ; I added a test case with some product options to be sure that the problem will be solve.
Last edit: 10 years 11 months ago by Jerome. Reason: fix "productmarket" > "ordermarket"
10 years 11 months ago #224130 by trevsmiff
Hi Jerome
I cant find those lines in the file 'components/com_hikamarket/views/productmarket/view.html.php'
What are the line numbers?
regards
Trevor
10 years 11 months ago - 10 years 11 months ago #224132 by trevsmiff
Did you mean "components/com_hikamarket/views/ordermarket/view.html.php" perhaps?
I have removed those lines from that file and the problem has been resolved thanks.
regards
Trevor
10 years 11 months ago #224135 by Jerome
Yes, ordermarket ; sorry for the confusion.
The following user(s) said Thank You: trevsmiff
