- Thank you received: 12
Vendor products list pagination problem
5 years 8 months ago #330402
by liaskas
Vendor products list pagination problem was created by liaskas
-- HikaShop version -- : 4.4.1
-- HikaMarket version -- : 3.1.1
-- Joomla version -- : 3.9.25
-- PHP version -- : 7.4.14
Hello
When vendor views his products list (vendor control panel/products) the pagination links always show the first page, even if the URL changes to product?limitstart=20&limit=20.
How can this be fixed?
Hello
5 years 8 months ago #330404
by Jerome
Replied by Jerome on topic Vendor products list pagination problem
I cannot reproduce the issue in the demo website (by forcing the pagination to a very low value in order to have several pages).
Would it be possible to have an access to your vendor panel to see the issue directly ?
Please use the contact us form to send us such private information (with a link to that forum thread so the support team will assign it to me).
5 years 8 months ago #330412
by liaskas
Replied by liaskas on topic Vendor products list pagination problem
All required info were sent through the contact us form.
Thank you
Thank you
5 years 8 months ago #330431
by Jerome
Thank you for the credentials.
I was able to see that you're not using the "category explorer" and that your issue is related to a patch I made in order to fix the pagination, but should be conditioned with the category explorer.
In the file "components/com_hikamarket/views/productmarket/view.html.php" please replace
By
And it will fix your issue.
That patch will be include in the next release.
if($cid != (int)$app->getUserState(HIKAMARKET_COMPONENT.'.product.listing_cid')) {
if($category_explorer && $cid != (int)$app->getUserState(HIKAMARKET_COMPONENT.'.product.listing_cid')) {
5 years 8 months ago #330432
by liaskas
Thank you Jerome, it worked.
By the way... is there a way to hide the limit selector just above the pagination so that we do not allow vendors to list more than 20 products?
Thank you
Thank you
5 years 8 months ago #330433
by Jerome
You can override the "productmarket / listing" view and change how the pagination is called.
I suppose that you can call directly the function "getPaginationLinks" with good options to not display the "limit" dropdown.
github.com/joomla/joomla-cms/blob/stagin.../Pagination.php#L533
I get that the option "showLimitBox" should do the job
github.com/joomla/joomla-cms/blob/stagin...nation/links.php#L54
For more details, I recommend you to contact the Joomla community.
<div class="hikamarket_pagination">
<?php echo $this->pagination->getListFooter(); ?>
<?php echo $this->pagination->getResultsCounter(); ?>
</div>
