Various Problems on Front End Variant Edit
4 years 5 months ago #341607 by daduts
-- url of the page with the problem -- : dadutscentral.com/index.php/component/hi...action-product/cid-4
-- HikaShop version -- : 4.5.1
-- HikaMarket version -- : 4.1.0
-- Joomla version -- : 4.1.0
-- PHP version -- : 7.4.29
-- Browser(s) name and version -- : 100.0 Firefox
Hey guys,
I'm having several problems when editing variants in the front end.
- the image delete button doesn't work
- the tinymce editor doesn't load
- delete button in my Specifications custom field doesn't work
- using upload button in Specification fields causes a "Access Forbidden" error
All of these functions work properly on the Product tab but not on the Variants.
The one problem on the Product tab is the tinymce window loads a bit funny with only the top half useable.
I've installed latest versions of HikaShop and HikaMarket
I've tested in both Rocket Theme and default templates.
The super user login I sent you for an earlier problem still shouid work.
Many thanks for your attention,
4 years 5 months ago #341614 by Jerome
All the issues you describe indicates a JavaScript error in the page which stop the execution of the JS.
In such case, best is to open the browser console and check for errors.
But in your case, I suppose it's something related to your template.
In the "Network", we can see that the content loaded do not include JavaScript.
The last line visible in that content is
<input type="hidden" name="data[variant][product_id]" value="546">
In the "productmarket/variant" view, after that line, some JavaScript is displayed so it can be processed by the page after the block is received.
If there is no JS in the page, the elements can't be initialized.
Seeing the source code of the page, we can see that "inline" JS is added in the "head" section of the page ; which mean that the content is modified by a plugin.
Regards,.
4 years 5 months ago #341615 by daduts
Hey Jerome,
Thanks again for the quick reply....on a weekend no less...thank you.
I reviewed my plugins and attempted shutting down anything that might re-position those scripts. Nothing I tried changed the behavior.
So, I tried another approach. I built a new "bare bones" site consisting only of Joomla 4.1 and the recent versions of HikaMarket and Hikashop I downloaded Friday.
I'm still getting the same non-performing scripts on the "bare bones" site !
I also saw a Notice appearing at the bottom of the Variants tab that I had missed before. I verified that this appears on the original site as well.
Notice: Array to string conversion in /home/safety/public_html/components/com_hikamarket/views/productmarket/tmpl/variant.php on line 248
You can checkout the "bare bones" site at dadutscentral.com/site2 .
I'll send you a user name and password via the contact form for site2.
Thanks again for your attention,
Cheers,
Dave
4 years 5 months ago #341616 by Jerome
Please edit the file "components/com_hikamarket/views/productmarket/view.html.php" and replace the line
protected $triggerView = true;
By
protected $triggerView = true; protected $allowInlineJavascript = true;
4 years 5 months ago #341617 by daduts
Thanks again Jerome.
That fixed most of it.
Site is still not loading the Description field properly when editing variants.
No title. No tinymce editor.
Verified that on "bare bones" site as well.
Cheers,
: D
4 years 5 months ago #341745 by daduts
Bump
Did you guys get a chance take a look at the missing editor in the Description field of the variants tab ?
Also, the notice is still there.
Thanks for your attention,
: D
4 years 5 months ago - 4 years 5 months ago #341784 by Jerome
I'm not forgetting you and I still need to reproduce the exact environment in order to understand the nature of the JS issue with your editor.
TinyMCE always been complicated since it was not designed to be compatible with Ajax system (and in Joomla, it doesn't appreciate multiple instances too, we need to use tricks).
When loading with ajax, an event is called so the editors can think a classical page is loaded and that it needs to initialize.
For the array notice, best would be to change the line with
if(is_string($script)) echo '<script type="text/javascript">'."\r\n".$script."\r\n".'</script>'; else hikashop_writeToLog($script, 'Debug Variant Scripts');
So the problematic content will be stored in the HikaShop Payment log, where you'll be able to see what kind of script cannot be added into the page (and so, be processed).
Last edit: 4 years 5 months ago by Jerome.
4 years 5 months ago - 4 years 5 months ago #341812 by daduts
Thanks Jerome,
Glad you're on the case. I'm getting ready to train clients on this form and am hoping to have it cleaned up before doing so.
Below is what appeared in the log after making the changes to the productmarket/variant view you suggested.
I'll need you to interpret if it means anything useful.
Thanks,
Dave
05.20.22 16:28:02 - Debug Variant Scripts Array ( [c24b8aee7a08a545f2d3daee275893eb] => window.hikashopFieldsJs = { 'reqFieldsComp': {}, 'validFieldsComp': {}, 'regexFieldsComp': {}, 'regexValueFieldsComp': {} }; [6978e0f1eb1b7219b9d06c00b9bcfb39] => function hikashopToggleFields(new_value, namekey, field_type, id, prefix) { if(!window.hikashop) return false; return window.hikashop.toggleField(new_value, namekey, field_type, id, prefix); } [5426f7caa4768202042e967460ff68eb] => setTimeout(function(){ (function($){ if(!window.hikashopLocal) window.hikashopLocal = {}; [e8f78d3aaf90887028abd742d0557c41] => try{WfEditor.init(..... )
4 years 5 months ago #341892 by Jerome
Sorry for the late reply.
You can use that code to avoid the Warning and fix the editor initialisation.
if(is_string($script)) echo '<script type="text/javascript">'."\r\n".$script."\r\n".'</script>'; else if(is_array($script)) echo '<script type="text/javascript">'."\r\n".implode("\r\n", $script)."\r\n".'</script>';
4 years 5 months ago #341994 by daduts
Hey Jerome,
Took me a couple days to get checking this one out.
I implemented the latest change.
We're still missing the Description title and the tinymce editor when editing variants.
I double checked this behavior on my "bare bones" site and verified it there as well.
Got another idea ?
Thanks,
Dave
4 years 5 months ago #342003 by Jerome
Are you using the same editor in the backend (WfEditor) ?
If you have correctly the patch, the JavaScript which was not added before (because it was condensed in an array, for a reason I do not know) should be available and processed.
I tried to take a look with the account you provided but it looks like it's not working anymore.
4 years 5 months ago #342011 by daduts
Hey Jerome,
I'm using jce in the backend.
I've got a new super user account for you. I'll send details via contact form.
Thanks again for your help,
Dave
4 years 5 months ago #342027 by Jerome
I was able to duplicate your environnement and reproduce your issue.
Some are related to modification in the Joomla 4 core regarding the way than the editor is initialized.
One trick used by HikaShop is no longer compatible with HikaMarket (depending an HTML element with an ID related to HikaShop).
So I made several patchs in order to retrieve the editor initialization without the HikaShop function ; I'll also propose that patch in order to improve the HikaShop core.
For the moment I've got a beta version of the next HikaMarket release (since I'm still working on some display improvements for Joomla 4 compatibility) but I can send you small patchs to apply to your version in order to make the editor working again.
4 years 5 months ago #342028 by daduts
That sounds like good news. Glad you were able to get to the root of the problem.
Please send the patches.
Many thanks
Dave
4 years 5 months ago #342054 by Jerome
I sent you the patch by email.
4 years 5 months ago #342078 by daduts
Thanks for the patch... It worked !..... sort of.
The patch works on my bare bones site on cassiopia.
It's doesn't work on my main site. I've stripped that page down to the rocketheme versla template and a couple of menu's. I checked it with admin tools disabled which had no effect.
Attached is a screen shot of the errors console is reporting.
The yellow warnings occur on page load.
The Reference error occurs when I click the Variants tab.
These errors don't appear on the bare bones Cassiopia site.
Got any more tricks up your sleeve ?
thanks,
Dave
4 years 5 months ago #342084 by Jerome
Looking at the content of the webpage, it looks like the editor you have for the variants is "mce_editable wf-editor" and not tinymce like for one for the main.
The error is there because the JS for the "wf-editor" was not loaded for the main page.
So I checked the code and see that for the variant, the code is looking in the HikaShop configuration and not the HikaMarket configuratin for the editor selection.
I suppose that you have TinyMCE in HikaMarket and JCE for HikaShop.
You have to edit the file "components/com_hikamarket/productmarket/view.html.php" and replace the lines
$editorType = $shopConfig->get('editor', ''); if(preg_match('/Edge/i', $_SERVER['HTTP_USER_AGENT'])) $editorType = 'none';
By
$editorType = $config->get('editor', ''); /* if(preg_match('/Edge/i', $_SERVER['HTTP_USER_AGENT'])) $editorType = 'none'; */
So we will be sure that the same editor is loaded for the main product and its variants.
4 years 5 months ago #342130 by daduts
Hey Jerome,
The code fix didn't work.
I couldn't find an editor setting in Hikashop so I assume it's pulling form the Joomla global config.
I set the Joomla global editor to tiny_mce to match the Hikamarket setting. That did the trick and presented the variable Description editor properly.
Thanks for your help,
Dave
4 years 5 months ago #342172 by Jerome
Even with the modification from "$shopConfig" to "$config" ?
That was an interesting point for me (and a fix that I'll keep in the next release).
4 years 5 months ago #342175 by daduts
That was the right question.
I had missed the $shopConfig to $config.
So I tried it again with that fix.
Threw an error...
Notice: Undefined variable: Config in /home/safety/public_html/components/com_hikamarket/views/productmarket/view.html.php on line 1197
: D
