Various Problems on Front End Variant Edit
4 years 5 months ago #342176 by daduts
Turns out $config is case sensitive. Changed to $config and it works !!!
Yeah !
: D
4 years 4 months ago #343011 by daduts
Hey Jerome,
Remember this one....the editor type mixup ?
It struck again....
I added a WYSIWYG custom field and it screwed up my front end product editing forms.
I verified in the backend that the wysisyg field is pulling the jce editor from, i believe, the Joomla Global Config. Meanwhile I have Hikamarket set to tiny_mce.
I was able to fix my issue by changing the global to tiny_mce.
Figured you'd wanna know about it.
cheers,
: D
4 years 4 months ago #343012 by Jerome
Custom fields are handle by HikaShop core system.
The HikaMarket settings can't interfere with it since it call HikaShop custom field system for the display.
Best would be to report that behavior to the HikaShop support team so they can look into it.
