Showing the vendor products - layout issues
13 years 8 months ago #93989 by theweasel68
I am having a product listing of a particular category.
The refering page is product / listing_table.php
I have commented the image code as I don´t want to show the product image.
1)
I would like to show the "sold by: vendor" field on the page, tried to find the code on the product detail page, but couldn´t find it. What would I have to include in order to include the "sold by: vendor" info
2)
How can I change the width of the product title in the table? (no description shown, only the title.
3)
The buttons are in white - I cant find the CSS to change in Hikashop, but also not in the CSS of my template. Any idea, where to change?
Pls. see also screenshot
Thx
13 years 8 months ago #94084 by Jerome
The "sold by: vendor" is displayed by HikaMarket itself using an HikaShop trigger.
During the product listing or the product page display, HikaShop call a trigger and HikaMarket stored some extra data in the product objects which would be displayed by HikaShop just after.
You can easily retrieve the vendor of a product with a little part of code.
// Include HikaMarket include_once rtrim(JPATH_ADMINISTRATOR,DS).DS.'components'.DS.'com_hikamarket'.DS.'helpers'.DS.'helper.php'; // Get the vendor class $vendorClass = hikamarket::get('class.vendor'); // Retrieve the vendor object from the "product_vendor_id" $vendor = $vendorClass->get( $product->product_vendor_id );
The width should be changed using CSS. I guess with a link to the page, I could give you more information.
The button color is made by your template CSS, you have to add a new CSS rule in order to change the color for this specific button (using the class or the id of the parent container).
www.hikashop.com/en/support/documentatio...ize-the-display.html
13 years 8 months ago - 13 years 8 months ago #94223 by theweasel68
Hi Jerome,
button color solved, thx...
The site is: www.club.schuch.at/index.php?option=com_...t=listing&Itemid=135
There you will see the product listing table
Don´t really know how to add a trigger call :( Do you have a tutorial somewhere or could you point me to a good description, from where i could get and learn how to? Many thx.
Last edit: 13 years 8 months ago by theweasel68.
13 years 8 months ago #94229 by Jerome
About your table, the first column is bigger because the last line have a long text.
The table is automatically adjust by the cell contents so, you have to force some width in order to adjust it.
Like:
.hikashop_products_listing .hikashop_products_table .hikashop_product_add_to_cart { width: 130px; }
About the vendor, you don't have to make the trigger. It is already made by HikaShop.
But I see that the extradata is not display in the table view so.
Please update in the view "product | listing_table" the content
<td class="hikashop_product_name_row"> <span class="hikashop_product_name"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_name; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </span> <!-- Begin of the part to add in the view --> <?php if(!empty($this->row->extraData->afterProductName)) { echo implode("\r\n",$this->row->extraData->afterProductName); } ?> <!-- End of the part to add in the view --> </td>
The following user(s) said Thank You: theweasel68
