Problem invoice hikamarket
12 years 11 months ago #137478 by publiduty
Hello
In the backend work the Invoice button fine, but in the frontend the pop-up not opens correct
Thanks!
12 years 11 months ago #137496 by Jerome
Replied by Jerome on topic Problem invoice hikamarket
You have a popup problem in HikaShop.
Please change the option "popup mode" in your HikaShop configuration so all popup related to HikaShop and HikaMarket will display fine in the front-end.
I think you are using the "boostrap popup" mode but your template is not compatible with. So using the "mootools" mode will be better.
PS: For your HikaMarket questions, please use the HikaMarket forum section otherwise I won't see it and I won't be able to answer you (until someone of the HikaShop team notify me).
