Setting vendor's products can not add into cart
12 years 3 months ago #165857 by liuchenbo
-- HikaMarket version -- : 1.4.1
-- Joomla version -- : 3.2
-- PHP version -- : 5.3.13
Hi, my website need set some vendor can not sell their products,
that means, customer should not add their products to cart, only check information of their product.
How to get it, thanks for your help.
12 years 3 months ago #165862 by Jerome
I think the best is to use a "product template" where the "product quantity" will be set to zero.
If you don't give the right to the vendors to change the product quantity (you remove the ACL product/edit/quantity) the product won't be available for customers (not possible to add a product in the cart if it does not have any stock).
The following user(s) said Thank You: liuchenbo
12 years 3 months ago #165902 by liuchenbo
Yes, that's a good idea.
Thanks a lot and there is a little problem,
may i replace "No stock" to " "(blank space) ,
because it looks stranger for some special products.
12 years 3 months ago #165903 by Jerome
Sure. It is an HikaShop translation, so you can use a translation override.
